How to install WordPress with Docker on a VPS or a dedicated server
Knowledge Base
Icons/System/eye-open Created with Sketch. 103 Views 13.03.2024 Cloud / Dedicated Server (bare metal)
Installing WordPress on a VPS or dedicated server has several advantages, such as full customization of the environment, performance optimization, and enhanced security. There are several ways to install WordPress on a VPS or dedicated server, depending on your technical level and the time you want to devote to it. One of the quickest and most efficient ways to do this is to use Docker. Docker makes it easy to deploy applications by 'containerizing' them, making WordPress installation fast, easy, and repeatable in any environment.
Find out how to install WordPress manually with Docker on a VPS or an OVHcloud Dedicated Server.
This tutorial will show you how to use one or more OVHcloud solutions with external tools, and the changes you need to make in specific contexts. You may need to adapt the instructions according to your situation.
We recommend that you contact a specialist service provider or reach out to our community if you face difficulties or doubts concerning the administration, usage or implementation of services on a server.
The VPS used for this guide has a Debian distribution in version 11 (Bullseye). For more information, see the official Docker website.
Install Docker
Update the package manager:
sudo apt update
Install the required packages to allow apt to use a repository over HTTPS:
sudo apt install apt-transport-https ca-certificates curl software-properties-common
Add the official Docker GPG key:
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
Add the Docker repository to your system:
echo "deb [arch=amd64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/debian bullseye stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
Update the apt package index and install the Docker Engine:
sudo apt update
sudo apt install docker-ce docker-ce-cli containerd.io -y
Verify that Docker is installed and configured:
docker –version
Test Docker with a simple command:
sudo docker run hello-world
If the Docker installation is successful, you will receive a message like this:
WP Docker VPS
Install Docker Compose
Download the latest version of Docker Compose (replace 1.29.2 with the latest available version):
sudo curl -L "https://github.com/docker/compose/releases/download/1.29.2/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
Make the binary executable:
sudo chmod +x /usr/local/bin/docker-compose
Check the Docker Compose installation:
docker compose version
If the Docker Compose installation is successful, you will receive a message like this:
WP Docker VPS
Deploy WordPress with Docker Compose
Create a folder for your WordPress project and navigate to it:
mkdir wordpress-docker && cd wordpress-docker
Create a docker-compose.yml file with your preferred text editor:
nano docker-compose.yml
Copy and paste the following configuration into the docker-compose.yml file:
version: '3.8'
services:
  db:
    image: mysql:5.7
    volumes:
      - db_data:/var/lib/mysql
    environment:
      MYSQL_ROOT_PASSWORD: wordpress
      MYSQL_DATABASE: wordpress
      MYSQL_USER: wordpress
      MYSQL_PASSWORD: wordpress
  wordpress:
    depends_on:
      - db
    image: wordpress:latest
    ports:
      - "8000:80"
    environment:
      WORDPRESS_DB_HOST: db:3306
      WORDPRESS_DB_USER: wordpress
      WORDPRESS_DB_PASSWORD: wordpress
    volumes:
      - wordpress_data:/var/www/html
volumes:
  db_data: {}
  wordpress_data: {}
This Compose file creates a WordPress service and a MySQL service.
Launch the services with Docker Compose:
sudo docker compose up -d
The Docker image used in this example is the official version wordpress:latest. This specific image is designed to work with an Apache web server. The official WordPress images on Docker Hub are regularly updated to include the latest stable PHP versions compatible with the current version of WordPress.
To find out the exact PHP version included in the wordpress:latest image at a specific time, you can run a container based on this image and check the PHP version directly.
Launch a temporary container with the image wordpress:latest:
docker run --rm wordpress:latest php -v
This command gives you an answer like this:
PHP 8.2.16 (cli) (built: Feb 16 2024 21:54:41) (NTS)
As a reminder, Docker images are updated regularly. The version of the components in wordpress:latest can therefore change over time, as new versions are published and integrated into the image.
If you wish, you can use another Docker image.
Use a specific Docker image
Go to the Docker Hub WordPress section and identify the image that fits your needs. For example, if you choose to use the image wordpress:5-php7.4-fpm, you will need to edit your docker-compose.yml file with a text editor. Once the file is open, find the section of the wordpress service and modify the line image: to use the specific tag of the wordpress:5-php7.4-fpm image you have chosen. For example:
version: '3.8'
services:
  wordpress:
    image: wordpress:5-php7.4-fpm
    container_name: wordpress
Apply changes
Launch or update your containers with Docker Compose. If this is your first time launching the project, use:
docker-compose up -d
If your containers are already running and you want to apply the changes, use:
docker-compose up -d --force-recreate
Check that everything is working as expected. You can check the logs of your WordPress container to ensure that it starts correctly and that there are no errors:
docker logs wordpress
Access WordPress
You can now access WordPress from a browser. There are two ways of doing this:
  • Via the IP address of your VPS: <VPS_IP_ADDRESS>:8000
  • Via your website’s domain name: <DOMAIN_NAME>:8000
To access your website from a browser, first link the domain name of your WordPress website to the IP address of your VPS. Go to your OVHcloud Control Panel.
In the left-hand menu, click Domain names, then select the domain name you have chosen for your WordPress website.
Click the DNS zone tab. In the table, identify the row with the value A, click on the button ... and select Modify record.
WP Docker VPS
In the window that pops up, enter the IP address of your VPS or dedicated server in the Target field, then click Next. Check that the information you have entered is correct, then click Confirm.
WP Docker VPS
Initialize your WordPress website
When you log in for the first time, your browser must redirect you to <VPS_IP_ADDRESS>:8000/wp-admin/install.php (or <DOMAIN_NAME>:8000/wp-admin/install.php if you use the domain name). This means that WordPress is ready for the initial configuration phase. This page is the starting point for configuring your WordPress website, where you need to define key elements such as:
  • Language
  • The title of your website
  • The username for site administration
  • An associated password
  • An email address
  • etc.
Complete the installation of your WordPress website
Once all the necessary information has been completed and the form has been submitted, WordPress will finalize the installation. You will then be redirected to the login screen (wp-login.php), where you can log in with the username and password you have just created.
WP Docker VPS
Conclusion
You have just installed WordPress on your VPS or OVHcloud dedicated server with a Docker image. You can now access your WordPress website from a browser.
For some general tips on securing a GNU/Linux-based server, see our guides:
How to install a web development environment on a VPS or a dedicated server
How to install WordPress with WP-CLI on a VPS or a dedicated server
Securing a VPS
Securing a dedicated server
Related articles
