Install Flask on your POWER web hosting plan
Bases de conhecimento
Icons/System/eye-open Created with Sketch. 63 visualizações 05.01.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Python applications, and you want to deploy Flask on it.
Find out how to install Flask on your POWER web hosting plan.
  • Runtime: Python 3.8
  • Entrypoint: app.py
  • DocumentRoot: www
cd www
virtualenv venv
source venv/bin/activate
Update pip:
pip install --upgrade pip
Install Flask.
pip install Flask
Create app.py with the following content, using the same trick to activate the virtualenv:
from flask import Flask
application = Flask(__name__)
@application.route('/')
def hello_world():
    return 'Hello, World!'
Then restart your instance and your Flask project will be online.
Flask
Terminal output:
~ $ cd www
~/www $ virtualenv venv
Collecting pip
  Attempting uninstall: pip
    Uninstalling pip-20.2.2:
~/www $ pip install Flask
Collecting Flask
  Using cached Flask-1.1.2-py2.py3-none-any.whl (94 kB)
Collecting itsdangerous>=0.24
  Using cached itsdangerous-1.1.0-py2.py3-none-any.whl (16 kB)
Collecting Werkzeug>=0.15
  Using cached Werkzeug-1.0.1-py2.py3-none-any.whl (298 kB)
Collecting click>=5.1
  Using cached click-7.1.2-py2.py3-none-any.whl (82 kB)
Collecting Jinja2>=2.10.1
  Using cached Jinja2-2.11.3-py2.py3-none-any.whl (125 kB)
Collecting MarkupSafe>=0.23
  Using cached MarkupSafe-1.1.1-cp38-cp38-manylinux2010_x86_64.whl (32 kB)
Installing collected packages: MarkupSafe, Werkzeug, Jinja2, itsdangerous, click, Flask
Successfully installed Flask-1.1.2 Jinja2-2.11.3 MarkupSafe-1.1.1 Werkzeug-1.0.1 click-7.1.2 itsdangerous-1.1.0
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Artigos relacionados
