Install Express on your POWER web hosting plan
Bases de conhecimento
Icons/System/eye-open Created with Sketch. 59 visualizações 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Node.js applications, and you want to begin developing your project using Express.
This guide will explain how to deploy a simple Hello World server on Express.
Find out how to install Express on your POWER web hosting plan.
  • Runtime: nodejs 14
  • Entrypoint: index.js
  • DocumentRoot: www
Connect via SSH to your POWER web hosting, and install Express using npm:
npm install express --save
Then go to the www folder and create an index.js file there:
index.js
const express = require('express');
const port = 3000;
const msg = `Hello World from NodeJS ${process.version}\n`;
const app = express();app.get('/', function (req, res) {
res.send(msg);
app.listen(port);
Restart your instance and your Express Hello World will be online.
Express Hello World
Terminal output:
~/www $ cd www
~/www $ node -v
v14.13.0
~/www $ npm install express --save
~/www $ vi index.js
const port = 3000;
res.send(msg);
app.listen(port);
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Artigos relacionados
