Configurar Fluxo Nutanix (EN)
Bases de conhecimento
Icons/System/eye-open Created with Sketch. 297 visualizações 08.04.2022 Cloud / Nutanix on OVHcloud
Nutanix Flow is available on all Nutanix on OVHcloud offers. This option secures the network in one or more clusters managed by Prism Central
Learn how to use Nutanix Flow for network security within a Nutanix cluster.
Log in to Prism Central.
To connect to a Nutanix cluster, if required, see the Go further section in this guide.
Enabling Nutanix Flow
Click the gear in the top right to change the settings.
Activate Flow 01
Click Microsegmentation from the scroll bar on the left.
Activate Flow 02
Select the Enable Microsegmentation checkbox and click Save.
Activate Flow 03
Microsegmentation is enabled. You can always disable it.
Activate Flow 04
Category configuration
A category is an object that can contain one or more values.
When installing a cluster, some categories already exist and can be modified, other categories can be added.
Entities, such as virtual machines, subnets, or images, can be among the categories used for a tool like Flow, for example.
Creating a category
From the main menu, click Categories on the Administration submenu.
Create Category 01
Click New Category.
Create Category 02
Type the name of the category in Name and Click New value.
Create Category 03
Type a name in Value and click the blue validation button on the right.
Create Category 04
Click Save.
Create Category 05
The new category appears in the category list.
Create Category 06
Modifying a Category
Select the Special-Computers category
Create Isolation Rule 02
Click Update on the Actions menu.
Create Isolation Rule 03
Click New value.
Create Isolation Rule 04
Enter a value in the Value column and click the validation icon.
Create Isolation Rule 05
Click New value.
Create Isolation Rule 06
Enter another value in the Value column and click the validation icon.
Create Isolation Rule 07
Click Save to commit the category change.
Create Isolation Rule 08
The category is visible in the category dashboard with these two new values.
Create Isolation Rule 09
Assigning a Category to a Virtual Machine
In the main menu, click VMs under Compute & Storage.
Add VM to Category 01
Select the virtual machine by ticking on the left.
Add VM to Category 02
Click Actions, then click Manage Categories.
Add VM to Category 03
Type categoryName:value and click the + sign.
Add VM to Category 04
Click Save to save the virtual machine to a category.
Add VM to Category 05
Assigning a category to multiple VMs
Select three virtual machines using the check boxes on the left.
Add category to multi VMs 01
Click the Actions menu and select Manage Categories.
Add category to multi VMs 02
Type categoryName:value and click +.
Add category to multi VMs 03
Click Save.
Add category to multi VMs 04
Assigning a Category to Subnets
From the main menu, click Subnets under Network & Security.
Add Category to subnet 01
Select the subnets by checking their left.
Add Category to subnet 02
Add Category to subnet 03
Add Category to subnet 04
Click Save.
Add Category to subnet 05
Network quarantine management
Network quarantine allows you to isolate a virtual machine from the entire network, or allow it restricted access to certain repair tools that are on the network.
VM quarantine
Add VM to Quarantine 01
Add VM to Quarantine 02
Click Actions and choose Quarantine VMs from the menu.
Add VM to Quarantine 03
Select Forensic in Quarantine Method and click Quarantine.
Add VM to Quarantine 04
The virtual machine is now in quarantine.
Customising the network quarantine.
There are currently no blockages affecting the quarantined virtual machine. Follow these instructions to configure the quarantine.
From the main menu, click Security Policies in the Network & Security submenu.
Configure Quarantine 01
Click the number next to Quarantined to view the quarantined virtual machines.
Configure Quarantine 02
The list of quarantined VMs appears in the Name column. Click Close to return to the previous menu.
Configure Quarantine 03
Click Quarantine below the Name column to edit the rule.
Configure Quarantine 04
The rule status is in monitoring mode, as shown in the top left-hand corner.
Traffic is not blocked but monitored. Connections between the quarantined VMs and the rest of the network are represented by orange lines attached to rectangles representing the IP address of the source or destination.
Click Enforce in the top right-hand corner to switch from Monitoring mode to Enforcing mode with traffic blocking.
Configure Quarantine 05
Type ENFORCE and click Confirm.
Configure Quarantine 06
The rule status is now on Enforced.
Traffic is blocked. We see attempts to access VMs in quarantines via red dotted lines to blocks containing the IP address of the VM.
Click Update in the top right-hand corner to edit the rule to allow certain network streams.
Configure Quarantine 07
Click Next.
Configure Quarantine 08
Move your mouse over an incoming connection attempt and click Allow Traffic
Configure Quarantine 09
Select the checkbox to the left of the Source to select the incoming discovered traffic, then click Allow 1 Discovered Traffic to allow only the discovered traffic, such as ICMP below.
Configure Quarantine 10
Move your mouse over an outgoing connection attempt and click Allow Traffic.
Configure Quarantine 11
Select the checkbox to the left of the Source to select the outbound discovered traffic, then click Allow 1 Discovered Traffic to allow only the discovered traffic.
Configure Quarantine 12
The authorised traffic is now visible via grey lines, while the blocked traffic is in red.
To create a rule manually without going through network discovery, left-click Add Source to allow an incoming connection to the quarantine.
Configure Quarantine 13
Enter the category name and its value in Add source by: Category, then click Add.
Configure Quarantine 14
The source appears in Configured.
Click + to the left of Quarantine: Forensics.
Configure Quarantine 15
Allow all traffic and click Save.
Configure Quarantine 16
Right-click Add Destination to allow an outgoing rule from quarantine.
Configure Quarantine 17
Enter the category name and its value in Add source by: Category, and then click Add.
Configure Quarantine 18
Click + to the right of Quarantine: Forensics.
Configure Quarantine 19
Configure Quarantine 20
Click Next.
Configure Quarantine 21
Click Save and Enforce to apply the quarantine rule changes.
Configure Quarantine 22
Click Quarantine to view quarantine rule details.
Configure Quarantine 23
The rule status is on Enforced, the Forensic mode has been customised.
A virtual machine in Strict mode will be completely isolated from the network, while in Forensic mode it will have access to the areas defined in the quarantine rule.
Configure Quarantine 24
Creating an isolation rule
An isolation rule allows blocking of network communications between two categories (virtual machines or subnets).
For more information about managing categories, see the Setting up categories section in this guide.
From the main menu, click Securities Policies in the Network & Security submenu.
Click Create Security Policy.
Select Isolation Policy and click Create.
Type the rule name in Name and then add a comment in Purpose, choose a category in Isolate this category, followed by another category in From this category.
Select Enforce in Select a Policy mode, then click Save and Enforce.
The rule is active in the list of security rules.
Click The rule name below the Name column to view details.
The status of the rule indicates Enforced, and you can see that no connection attempt between the two zones is detected, as this message indicates: No Traffic between them has been discovered.
If a network connection attempt is detected between these two zones, the message changes to Traffic between them has been discovered.
Setting up an application rule.
An application rule limits access to certain ports, protocols, or services for members of a category from another category.
This rule can only be used with a category named Applications that can be edited but not deleted.
Create Application Rule 01
Create Application Rule 02
Select Secure Application (App Policy) and click Create.
Create Application Rule 03
Enter the Name fields for the rule name, Purpose for comment, Secure this App by choosing an existing application category, and click Next.
Create Application Rule 04
Click Add Source on the left.
Create Application Rule 05
Choose the category for the VLAN and click Add.
Create Application Rule 06
Click + to connect the application to the source.
Create Application Rule 07
Select Select a Service, choose the category in Protocol/Service, search for the service name in Port/Service Details, and click Save.
Create Application Rule 08
Click Next.
Create Application Rule 09
Select Enforce and click Save and Enforce to enable this rule.
Create Application Rule 10
The rule you created is in the list of rules.
Create Application Rule 11
Hiperconvergência Nutanix (EN)
Presentation of Nutanix FLOW
Nutanix FLOW security rules
Categories in Nutanix
Artigos relacionados
