Zarządzanie segmentami w NSX (EN)
Bazy wiedzy
Icons/System/eye-open Created with Sketch. 279 wyśw. 23.02.2024 Cloud / VMware
In an NSX solution a segment is a virtual level 2 domain, it can be of two types :
  • VLAN-backed segments : Communication between hosts and virtual machines is done through VLANs and a Layer 2 switch of the OSI model. In order for these segments to communicate with the elements of NSX (Internet and other segments), an interface must be added to the Tier-1 Gateways or Tier-0 Gateways gateways.
  • Overlay-backed segments: The connection is made using a software overlay that establishes tunnels between hosts. You must add an address to a subnet that will be used for routing outside this segment. They must be connected to a Tier-1 Gateways gateway such as ovh-T1-gw.
The segments are linked to transport zones that are predefined by OVHcloud.
  • system-owned-vlan-transport-zone-for-rtep | VLAN : Area for extended RTEP networks.
  • system-owned-vlan-transport-zone-for-evpn | VLAN : Zone for VPNs.
  • ovh-tz-overlay | VLAN : Zone for Overlay segments behind the ovh-t1-gw gateway.
  • ovh-tz-public | VLAN : Area connected to the public network on a single VLAN provided by OVHcloud.
  • ovh-tz-vrack | VLAN : Area connected to the OVHcloud vRack where it is possible to create segments with a particular VLAN.
Discover the creation and use of segments in the NSX and vCenter interfaces.
This guide is designed to assist you as much as possible with common tasks. However, we recommend contacting a specialist provider if you experience any difficulties or doubts when it comes to managing, using or setting up a service on a server.
Please note that the designations (such as the VLAN number) and IP addresses of the network configurations are provided as examples, and can be modified if required.
Creating a segment in the NSX interface
We will create an Overlay-backed segment connected to ovh-T1-gw in a subnet in 192.168.1.0/24 with gateway 192.168.1.254.
From the NSX interface go to the Networking tab.
01 Create Segment 01
Click on Segments on the left.
01 Create Segment 02
Click on ADD SEGMENT on the right.
01 Create Segment 03
Fill-in this information:
  • Name: Your segment name.
  • Connected Gateway: Predefined gateway ovh-T1-gw | Tier1.
  • Transport Zone: ovh-tz-overlay predefined zone.
  • Subnet: The gateway address of the segment in this format 192.168.1.254/24.
Then click on SAVE on the right.
01 Create Segment 04
Click NO when prompted.
01 Create Segment 05
The new segment appears in the list.
01 Create Segment 06
In the Networking tab, click on Network Topology on the left to see the new segment and its location in the network.
02 Display Network Topology 01
Connecting a virtual machine to this segment.
Go to the vCenter interface of your Hosted Private Cloud cluster.
Right-click the virtual machine and click Edit Settings.
03 Connect Network Card to Segment 01
Scroll to the right of your network adapter and choose Browse.
03 Connect Network Card to Segment 02
Select the network that is named after your segment and click OK.
03 Connect Network Card to Segment 03
Click OK.
03 Connect Network Card to Segment 04
Now that your virtual machine is connected to the segment, go back to the NSX interface.
Go to the Networking tab, choose Network Topology.
04 display network topology with one segment and one vm 01
The virtual machine associated with the network appears in the network topology.
Use the first part of the guide to create a second segment named ov2-segment with these parameters 192.168.2.254/24 in order to have two segments connected to ovh-T1-gw.
05 display four VM on two segment01
Then, from the vCenter console, put two virtual machines on the first segment and two more on the second segment.
Return to the NSX interface in Network Topology to bring up the new network configuration.
05 display four VM on two segment02
Both segments are connected to the gateway ovh-T1-gw. Routing between the two subnets is enabled without any network restrictions by default.
Creating a segment on a VLAN
Through the NSX interface, click on the Networking tab and click on Segments on the left in the Connectivity section. Then click ADD SEGMENT.
06 Add vlan segment 01
Fill in this information :
  • Name : Type vlan100-vrack-segment.
  • Transport Zone : Select ovh-tz-vrack.
  • VLAN : Write the number 100.
  • Subnets : Enter the gateway address and range on this segment 192.168.100.254/24
Then click SAVE.
06 Add vlan segment 02
06 Add vlan segment 03
Connecting a VLAN segment to the ovh-T1-gw gateway
You can route the network from a VLAN segment to the Internet and other segments by creating an interface on the ovh-T1-gw gateway. When creating the interface, use the same IP address as the one specified in the segment subnet.
Through the NSX interface go to the Networking tab and click on Tier-1 Gateways on the left in the Connectivity section.
Then click on the three vertical points and choose Edit from the menu.
07 add interfaces to ovh-T1-gw with vlan 01
Click on the Down Arrow to the left of SERVICE INTERFACES and click the Set button that just appeared to the right of Service Interfaces.
07 add interfaces to ovh-T1-gw with vlan 02
Click ADD INTERFACE.
07 add interfaces to ovh-T1-gw with vlan 03
Choose this information :
  • Name : Type vlan100-interface as the name of your interface.
  • IP Address / Mask : Enter the IP address of the interface 192.168.100.254/24 that should match the gateway.
  • Connected To(Segment) : Take the segment that is on vlan 100 on the vRack named vlan100-vrack-segment.
Then click SAVE to confirm the creation of the interface on ovh-T1-gw.
07 add interfaces to ovh-T1-gw with vlan 04
Click CLOSE.
07 add interfaces to ovh-T1-gw with vlan 05
The number 1 next to Service Interfaces indicates that the interface is created, click CLOSE EDITING to complete the creation of the interface.
You can now connect outside this segment through the interface with gateway 192.168.100.254/24.
Assigning a VLAN Segment to a Virtual Machine
Go to your vSphere interface; right-click your virtual machine and choose Change settings.
08 connect VM to VLAN segment 01
Go to your network adapter and click Browse.
08 connect VM to VLAN segment 02
Click the segment associated with your VLAN and click OK.
08 connect VM to VLAN segment 03
Click OK to commit the changes.
08 connect VM to VLAN segment 04
Displaying a network topology with overlay segments and other segments on VLANs
Go back to the NSX interface, go to the Networking tab and click on Network Topology on the left to view a graphical view of the network. You will see networks of type Overlay and those of type VLAN connected through an interface on ovh-t1-gw.
09 display network topology vlan overlay01
Getting started with NSX
Powiązane artykuły
