Install Django on your POWER web hosting plan
Bazy wiedzy
Icons/System/eye-open Created with Sketch. 93 wyśw. 05.01.2023 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Python applications, and you want to deploy Django on it.
Find out how to install Django on your POWER web hosting plan.
  • Runtime: Python 3.8
  • Entrypoint: app.py
  • DocumentRoot: www
~$ cd www
~/www$ virtualenv venv
~/www$ source venv/bin/activate
Update pip:
~/www$ pip install --upgrade pip
Install Django:
~/www$ pip install django
Create the new Django project:
~/www$ django-admin startproject config
By default, Django's wsgi application is located in config/wsgi.py. As our configured hosting entrypoint is app.py, we can create the following symlink:
~/www$ ln -s config/wsgi.py app.py
As Django is installed inside a virtualenv, we should tell the app to use it. We can do so by adding these 2 lines in app.py before Django import:
The complete app.py file:
WSGI config for config project.
It exposes the WSGI callable as a module-level variable named ``application``.
For more information on this file, see
https://docs.djangoproject.com/en/3.1/howto/deployment/wsgi/
import os
from django.core.wsgi import get_wsgi_application
os.environ.setdefault('DJANGO_SETTINGS_MODULE', 'config.settings')
application = get_wsgi_application()
Django needs to declare the allowed hosts used for the website. It's configured in config/settings.py, for example:
ALLOWED_HOSTS = ['yourdomainname', 'www.yourdomainname', 'yourFTPuser.cluster022.hosting.ovh.net']
Then restart your instance and your Django will be online.
Django
Terminal output:
~ $ cd www
~/www $ virtualenv venv
Collecting pip
  Attempting uninstall: pip
    Uninstalling pip-20.2.2:
~/www $ pip install django
Collecting django
  Downloading Django-3.1.6-py3-none-any.whl (7.8 MB)
     |████████████████████████████████| 7.8 MB 13.0 MB/s
Collecting pytz
  Downloading pytz-2021.1-py2.py3-none-any.whl (510 kB)
     |████████████████████████████████| 510 kB 65.6 MB/s
Collecting asgiref<4,>=3.2.10
  Downloading asgiref-3.3.1-py3-none-any.whl (19 kB)
Collecting sqlparse>=0.2.2
  Downloading sqlparse-0.4.1-py3-none-any.whl (42 kB)
     |████████████████████████████████| 42 kB 1.2 MB/s
Installing collected packages: sqlparse, pytz, asgiref, django
Successfully installed asgiref-3.3.1 django-3.1.6 pytz-2021.1 sqlparse-0.4.1
~/www $ django-admin startproject config .
~/www $ ln -s config/wsgi.py app.py
~/www $ cat app.py
import os
~/www $ cat config/settings.py
Django settings for config project.
Generated by 'django-admin startproject' using Django 3.1.6.
https://docs.djangoproject.com/en/3.1/topics/settings/
For the full list of settings and their values, see
https://docs.djangoproject.com/en/3.1/ref/settings/
from pathlib import Path
# Build paths inside the project like this: BASE_DIR / 'subdir'.
BASE_DIR = Path(__file__).resolve().parent.parent
# Quick-start development settings - unsuitable for production
# See https://docs.djangoproject.com/en/3.1/howto/deployment/checklist/
# SECURITY WARNING: keep the secret key used in production secret!
SECRET_KEY = '83sh7zk*@1w#z3&oa@%5b-@iejc_4tl5))@niu1u882k*8h7kp'
# SECURITY WARNING: don't run with debug turned on in production!
DEBUG = True
ALLOWED_HOSTS = [ 'power.lostinbrittany.dev', 'xxxx.xxxx.hosting.ovh.net' ]
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
More information on Django
To get more information on Django, go to the official documentation site.
Powiązane artykuły
