Install Etherpad on your POWER web hosting plan
Bazy wiedzy
Icons/System/eye-open Created with Sketch. 72 wyśw. 27.04.2023 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Node.js applications, and you want to deploy an Etherpad server on it.
Find out how to install Etherpad on your POWER web hosting plan.
  • Runtime: nodejs 14
  • Entrypoint: index.js
  • DocumentRoot: www
Access via SSH to your POWER web hosting, and retrieve Etherpad sources into the www folder:
cd www
git init
git remote add origin https://github.com/ether/etherpad-lite.git
git pull origin refs/tags/1.8.6
Etherpad 1.8.7 is not compatible with POWER web hosting because we currently do not support the "experimental-worker" option.
Then install Etherpad dependencies and set up the entry point:
bash bin/installDeps.sh
ln -fs node_modules/ep_etherpad-lite/node/server.js index.js
Restart your instance and your Etherpad will be online.
Etherpad
Terminal output:
~ $ node -v
v14.15.4
~ $ rm -rf www
~ $ mkdir www
~ $ cd www
~/www $ git init
~/www $ git remote add origin https://github.com/ether/etherpad-lite.git
~/www $ git pull origin refs/tags/1.8.6
remote: Enumerating objects: 2, done.
remote: Counting objects: 100% (2/2), done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 36100 (delta 1), reused 0 (delta 0), pack-reused 36098
Receiving objects: 100% (36100/36100), 16.57 MiB | 14.04 MiB/s, done.
Resolving deltas: 100% (25484/25484), done.
From https://github.com/ether/etherpad-lite
 * branch            release/1.8.6     -> FETCH_HEAD
 * [new branch]      release/1.8.6     -> origin/master
Checking out files: 100% (492/492), done.
~/www $ bash bin/installDeps.sh
Copy the settings template to settings.json...
Ensure that all dependencies are up to date...  If this is the first time you have run Etherpad please be patient.
> wd@1.12.1 install /home/powerlp/www/src/node_modules/wd
> node scripts/build-browser-scripts
added 799 packages in 11.642s
Clearing minified cache...
~/www $ ln -fs node_modules/ep_etherpad-lite/node/server.js index.js
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Powiązane artykuły
