Zarządzanie wirtualnymi maszynami (EN)
Bazy wiedzy
Icons/System/eye-open Created with Sketch. 316 wyśw. 10.05.2022 Cloud / Nutanix on OVHcloud
Find out how to manage virtual machines in a Nutanix cluster, and how to create and migrate a virtual machine.
Some software requires a licence such as Microsoft products, so make sure that all installed systems and software have these licences.
  • a Nutanix cluster in your OVHcloud account
  • You must be connected to Prism Central on the cluster
Overview of Virtual Machine Management in Prism Central
The Nutanix system uses the same interfaces to manage storage and virtualisation, it can be installed with multiple hypervisors (Hyper-V, VMware ESXi, AHV). AHV comes with Nutanix without the need to purchase additional licences for the hypervisor.
The OVHcloud solution is delivered with the AHV hypervisor.
AHV enables:
  • Using virtual machines on Windows and Linux.
  • Migrating virtual machines from one node to another in a cluster.
  • Micro-segmentation and network security between virtual machines using Flow software.
The Move tool makes it easy to migrate existing virtual machines in other environments (ESXi, Hyper-V & AWS) to Nutanix and its AHV hypervisor.
For more information on AHV, see the Go further section of this guide.
The following instructions show the creation of a virtual machine in Windows Server 2022 and the migration of a virtual machine.
Creating a Virtual Machine for a Windows 2022 Operating System
Installing a virtual machine on Windows Server 2022 requires a particular setup because Microsoft does not provide the driver for the AHV hypervisor disk controller.
Creating a Windows Server 2022 VM
In the left-hand menu of Prism Central, expand Compute & Storage and click VMs
Prism Central Dashboard - VM Menu
Click the Create VM button.
Prism Central dashboard - VM management
Type a name in Name, choose the options in VM Properties and click Next
Creating a virtual machine - Step 1
Adding a system disk
Click the Attach Disk button.
Creating a virtual machine - Step 2
Enter 60 in the Capacity field and click Save to create a 60 GB disk.
Creating a virtual machine - Step 3
Adding Windows Server 2022 Installation ISO Image
The image must be imported before it can be used in a new virtual machine.
For more information on importing images, see the Go further section of this guide.
Click Attach Disk.
Creating a virtual machine - Step 4
Change the Type settings to CD-ROM, Operation to Clone from Image, Image to WS2022EN.ISO.
Click Save.
Creating a virtual machine - Step 5
Adding an ISO image containing AHV-specific drivers
This image contains the disk controller driver and should also be imported. It is available on the Nutanix website if you have a Nutanix customer account.
Click Attach Disk.
Creating a virtual machine - Step 6
Change the Type settings to CD-ROM, Operation to Clone from Image, Image to Nutanix-VirtIO-1.1.7.iso.
Click Save.
Creating a virtual machine - Step 7
Network configuration
Click Attach Subnet.
Creating a virtual machine - Step 8
Leave the default fields and click Save.
Creating a virtual machine - Step 9
Click Next.
Creating a virtual machine - Step 10
Select your timezone and click Next.
Creating a virtual machine - Step 11
Click Create VM.
Creating a virtual machine - Step 12
The newly created virtual machine will then appear in the dashboard.
VM dashboard - VM Created.
Windows Server 2022 setup
Select the virtual machine on which you want to install Windows Server 2022, by ticking the box to the left of the VM.
Installation - WS2022 - Launch
Powering on the virtual machine
Click the Actions menu then Power ON.
Installation - WS2022 - Startup
Launching the console
Click the Actions menu then Launch Console.
Installation - WS2022 - Interface Connection
Starting the installation
Choose your local settings and click Next.
Installation - WS2022 - Etape1
Click Install now.
Installation - WS2022 - Step2
Select Windows Server 2022 Standard (Desktop Experience) and click Next.
Installation - WS2022- Etape3
Review the Microsoft software licence terms and conditions, accept them and click Next.
Click Custom: Install Microsoft Server Operating System only (advanced).
Click on Load driver.
Installation - WS2022- Step4
Click Browse.
Installation - WS2022- Step5
Select the correct folder e:\Windows Server 2022\amd64 and click OK.
Select these drivers:
  • Nutanix VirtIO Balloon Driver
  • Nutanix VirtIO Ethernet Adapter
  • Nutanix VirtIO SCSI pass-through controller
  • QEMU FWCfg Device
Click Next.
Installation - WS2022- Step6
The 60 GB disk will appear, click Next.
Enter and confirm the password in both fields and click Finish.
Installation - WS2022- Step9
Windows Server 2022 and WS2022 specific drivers for the AHV hypervisor have been installed.
Installing NGT (Nutanix Guest Tools)
NGT are tools that enable better interaction with Nutanix, particularly in terms of backups and snapshots.
Start the virtual machine console, right-click a CDROM drive, and click Eject.
NGT Installation 1
Go back to Prism Central and select the virtual machine.
NGT Installation 2
On the Actions menu, click Install NGT.
NGT Installation 3
Click Confirm & Enter Password.
NGT Installation 4
Click Skip and Mount.
NGT Installation 5
Return to the virtual machine console and right-click the CDROM drive containing the NGT.
Click Install Nutanix Guest Tools.
NGT Installation 6
Review the terms and conditions, accept them, then click Install.
NGT Installation 7
The installation will then begin.
NGT Installation 8
Once the installation is complete, close the installation wizard using the Close button.
NGT Installation 9
The installation of a virtual machine on Windows is then complete.
Migrating a virtual machine
Migrating a virtual machine involves moving a hot VM from one node to another in a cluster.
If you have several clusters and the appropriate licences, you can also migrate a VM from one cluster to another.
This guide only shows you how to migrate a VM within the same cluster.
In Prism Central VM Management, click WS2022N.
Migrate - VM01
Check which node the VM is currently running on. It is displayed next to Host.
Migrate - VM02
Click the More button, then Migrate.
Migrate - VM03
Choose a destination node.
Migrate - VM04
The name of the new node will appear in front of Host if the migration is complete.
Migrate - VM05
Presentation of a Nutanix cluster
Importing images into Nutanix
Nutanix documentation on AHV
Nutanix licences
Powiązane artykuły
