Advance Dedicated Servers - Upgrading your Samsung NVMe PM9A1 firmware (EN)
Bazy wiedzy
Icons/System/eye-open Created with Sketch. 411 wyśw. 18.10.2023 Cloud / Serwer dedykowany (bare metal)
Routine firmware updates play a pivotal role in upholding your NVMe drives' performance, stability, and security. Such updates often encompass critical bug fixes, enhanced compatibility, and advanced security features that are indispensable for preserving your data integrity and maintaining optimal operational efficiency.
Firmware changelog : https://last-public-ovh-baremetal.snap.mirrors.ovh.net/hardware/PM9A1/PM9A1_FW_Change_Notification_for_General_customer_v2.1_PDF.pdf
The purpose of this guide is to help you upgrade your NVMe Samsung PM9A1 firmware.
  • An Advance Dedicated Server with NVMe Samsung PM9A1, from the following:
    • Advance-1
    • Advance-2
    • Advance-3
    • Advance-4
    • Advance-5
    • Advance-6
  • Before attempting any firmware update, a backup of the data on the drive must be made. Use our guide on Backup Storage to learn how to back up your data.
  • The firmware update does not format the data, but a firmware update failure may happen. Please do not power off the drive or the bare metal server during the firmware update process.
Linux
Hardware/software configuration tested on OVHcloud side
The tests have been performed without SED configuration.
PlatformFlash toolFirmwareResult
Debian 11 OS + data in clear from diskcli 1.12GXA7802QOK
Ubuntu 22.04 OS + data in clear from disknvme-cli 1.16GXA7802QOK
Rocky 8 OS + data in clear from disknvme-cli 1.16GXA7802QOK
Debian 11 OS + data in clear from disk + RAIDnvme-cli 1.12GXA7802QOK
Ubuntu 22.04 OS + data in clear from disk + RAIDnvme-cli 1.16GXA7802QOK
Rocky 8 OS + data in clear from disk + RAIDnvme-cli 1.16GXA7802QOK
Step 1 - Install nvme-cli
You can install nvme-cli from your distribution's package manager.
  • For RHEL, CentOS, RockyLinux, AlmaLinux, Fedora and similar:
sudo dnf install nvme-cli
  • For Debian, Ubuntu, Mint, Proxmox and similar:
sudo apt install nvme-cli
Step 2 - List NVMe drives
The nvme list command lists all NVMe devices on your server:
sudo nvme list | grep 'Node\|MZVL2512HCJQ-00B07'
Node             SN                   Model                                    Namespace Usage                      Format           FW Rev
/dev/nvme0n1     S63CNX0T124339       SAMSUNG MZVL2512HCJQ-00B07               1           8.63  GB / 512.11  GB    512   B +  0 B   GXA7602Q
/dev/nvme1n1     S63CNX0RA09597       SAMSUNG MZVL2512HCJQ-00B07               1          11.06  GB / 512.11  GB    512   B +  0 B   GXA7602Q
We added a filter on this command to only display the SAMSUNG MZVL2512HCJQ-00B07 NVME, because the firmware update only concerns this NVMe reference and your server may have other disks connected to it.
Step 3 - Check if a firmware updated is needed
The firmware of each drive is displayed in the FW Rev column.
If the firmware version for all your drive is already version GXA7802Q, your firmware is up to date and you do not need to continue this process.
On the other hand, if at least one firmware is different from version GXA7802Q, you must proceed to the update detailed in step 4.
Step 4 - Firmware update
Download the firmware binary on your server :
wget https://last-public-ovh-baremetal.snap.mirrors.ovh.net/hardware/PM9A1/GXA7802Q_Noformat.bin
Execute the following command for each identified drive with a firmware different from version GXA7802Q:
In your command, replace X with the NVME node listed in step 2.
sudo nvme fw-download --fw GXA7802Q_Noformat.bin /dev/nvmeX
sudo nvme fw-activate --slot 0x1 --action 0x1 /dev/nvmeX
  • Example:
In our previous example both NVMe drives need a firmware update to the latest version GXA7802Q. Here's how we update the 2 NVMe drives and the command line returns:
root@labo:/home/ubuntu# sudo nvme fw-download --fw GXA7802Q_Noformat.bin /dev/nvme0
Firmware download success
root@labo:/home/ubuntu# sudo nvme fw-activate --slot 0x1 --action 0x1 /dev/nvme0
Success committing firmware action:1 slot:1
Multiple Update Detected (MUD) Value: 0
root@labo:/home/ubuntu# sudo nvme fw-download --fw GXA7802Q_Noformat.bin /dev/nvme1
root@labo:/home/ubuntu# sudo nvme fw-activate --slot 0x1 --action 0x1 /dev/nvme1
At this point the firmware update is complete, please reboot your server.
Step 5 - Check the firmware version after the server reboot
You can use the same nvme list command which lists all NVMe drives on your server:
/dev/nvme0n1     S63CNX0T124339       SAMSUNG MZVL2512HCJQ-00B07               1           8.63  GB / 512.11  GB    512   B +  0 B   GXA7802Q
/dev/nvme1n1     S63CNX0RA09597       SAMSUNG MZVL2512HCJQ-00B07               1          11.06  GB / 512.11  GB    512   B +  0 B   GXA7802Q
Your NVMe drive now should have the firmware version GXA7802Q.
ESXi
ESXi 7.0 U3j OS + data in clear from diskesxcli 7.0.0GXA7802QOK
ESXi 7.0 U3j OS + data in clear from disk + RAIDesxcli 7.0.0GXA7802QOK
Step 1 - List NVMe drives
The nvme controller list command lists all NVMe devices on your server:
esxcli nvme controller list | grep -i 'PM9A1\|Adapter'
Name                                                   Controller Number  Adapter  Transport Type  Is Online
nqn.1994-11.com.samsung:nvme:PM9A1:M.2:S63CNX0TC10818                256  vmhba2   PCIe                 true
nqn.1994-11.com.samsung:nvme:PM9A1:M.2:S63CNX0TC10816                257  vmhba1   PCIe                 true
We added a filter on this command to only display the PM9A1 NVMe, because the firmware update only concerns this NVMe reference and your server may have other disks connected to it.
Step 2 - Check if a firmware update is needed
For each NVMe in the previous list, we have to check the firmware version :
esxcli nvme device get -A vmhbaX | egrep "Model Number|Firmware Revision"
  • Example:
[root@labo:~] esxcli nvme device get -A vmhba2 | egrep "Model Number|Firmware Revision"
Model Number: SAMSUNG MZVL2512HCJQ-00B07
Firmware Revision: GXA7602Q
[root@labo:~] esxcli nvme device get -A vmhba1 | egrep "Model Number|Firmware Revision"
If the Firmware Revision for all your NVMe is already version GXA7802Q, your firmware is up to date and you do not need to continue this process.
On the other hand, if at least one firmware is different from version GXA7802Q, you must proceed to the update detailed in step 3.
Step 3 - Firmware update
  • Replace X with the NVME node listed in step 2.
  • Replace [path-to-firmware] with the actual firmware image path.
esxcli nvme device firmware download -A vmhbaX -f /[path-to-firmware]/GXA7802Q_Noformat.bin
esxcli nvme device firmware activate -a 1 -A vmhbaX -s 1
  • Example:
In our previous example both NVMe drives needed a firmware update to the latest version GXA7802Q.
Here's how we updated the 2 NVMe drives and the command line returns:
[root@labo:~] esxcli nvme device firmware download -A vmhba2 -f /GXA7802Q_Noformat.bin
Download firmware successfully.
[root@labo:~] esxcli nvme device firmware activate -a 1 -A vmhba2 -s 1
Commit firmware successfully, but activation requires reboot.
[root@labo:~] esxcli nvme device firmware download -A vmhba1 -f /GXA7802Q_Noformat.bin
[root@labo:~] esxcli nvme device firmware activate -a 1 -A vmhba1 -s 1
At this point the firmware update is complete, you need to reboot your server.
Step 4 - Check the firmware version after the server reboot
You can use the same command as in step 2 to check the firmware versions on your server:
   Firmware Revision: GXA7802Q
Windows
Windows 2016 + data in clear from diskSamsung DC Toolkit 2.1.W.Q.0GXA7802QOK
Windows 2019 + data in clear from diskSamsung DC Toolkit 2.1.W.Q.0GXA7802QOK
Windows 2022 + data in clear from diskSamsung DC Toolkit 2.1.W.Q.0GXA7802QOK
Windows 2016 + data in clear from disk + RAIDSamsung DC Toolkit 2.1.W.Q.0GXA7802QOK
Windows 2019 + data in clear from disk + RAIDSamsung DC Toolkit 2.1.W.Q.0GXA7802QOK
Windows 2022 + data in clear from disk + RAIDSamsung DC Toolkit 2.1.W.Q.0GXA7802QOK
Step 1 - Download Samsung DC Toolkit for Windows
Download the Samgung DC Toolkit via this link.
Tool version: Samsung DC Toolkit Version 2.1.W.Q.0
Step 2 - List drives and firmware versions
Open Windows Command Prompt as Administrator, then use the following command in the directory where the DC Toolkit was downloaded:
Samsung_SSD_DC_Toolkit_for_Windows_1.exe -L
Step 3 - Check if a firmware update is needed
The following command lists all the devices on your server:
C:\Users\admin\Downloads>Samsung_SSD_DC_Toolkit_for_Windows_1.exe -L
Copyright (C) 2017 SAMSUNG Electronics Co. Ltd. All rights reserved.
| Disk   | Path               | Model                      | Serial         | Firmware | Optionrom | Capacity | Drive  | Total Bytes | NVMe Driver          |
| Number |                    |                            | Number         |          | Version   |          | Health | Written     |                      |
| 0:c    | \\.\PHYSICALDRIVE0 | SAMSUNG MZVL2512HCJQ-00B07 | S63CNF0T114133 | GXA7602Q | N/A       |   476 GB | GOOD   |  0.00 TB    | Windows Inbox Driver |
| 1:c    | \\.\PHYSICALDRIVE1 | SAMSUNG MZVL2512HCJQ-00B07 | S63CNF0T114205 | GXA7602Q | N/A       |   476 GB | GOOD   |  0.00 TB    | Windows Inbox Driver |
This command displays all the disks present in the server. Only the lines SAMSUNG MZVL2512HCJQ-00B07 have to be checked.
The firmware of each drive is displayed in the Firmware column.
If the firmware version for all your drives is already version GXA7802Q, your firmware is up to date and you do not need to continue this process.
Download the firmware binary on your server : https://last-public-ovh-baremetal.snap.mirrors.ovh.net/hardware/PM9A1/GXA7802Q_Noformat.bin
  • Replace <X> with the Disk Number listed in step 3.
  • Replace <firmware directory> with the directory where the firmware is located.
Samsung_SSD_DC_Toolkit_for_Windows_1.exe --disk <X> ---firmware-download --path <firmware directory>GXA7802Q_Noformat.bin --action 1 --slot 1
  • Example:
In our previous example both NVMe drives needed a firmware update to the latest version GXA7802Q. Here's how we updated the 2 NVMe drives and the command line returns:
C:\Users\admin\Downloads>Samsung_SSD_DC_Toolkit_for_Windows_1.exe --disk 0:c --nvme-firmware-download --path C:\Users\admin\Downloads\GXA7802Q_Noformat.bin --action 1 --slot 1
Disk Number: 0:c | Model Name: SAMSUNG MZVL2512HCJQ-00B07 | Firmware Version: GXA7602Q
[[ WARNING ]]
Please Note that Firmware Update may format the disk and you will lose your data
Please Ensure that data backup is taken before proceeding to Firmware Update
If you are sure then only proceed, otherwise restart the application after taking a backup
Continue Firmware image download ? [ yes ]: yes
[SUCCESS] Downloaded firmware image successfully
C:\Users\admin\Downloads>Samsung_SSD_DC_Toolkit_for_Windows_1.exe --disk 1:c --nvme-firmware-download --path C:\Users\admin\Downloads\GXA7802Q_Noformat.bin --action 1 --slot 1
Disk Number: 1:c | Model Name: SAMSUNG MZVL2512HCJQ-00B07 | Firmware Version: GXA7602Q
[[ WARNING ]]
You can use the same command as in step 2 to list all NVMe drives on your server:
| 0:c    | \\.\PHYSICALDRIVE0 | SAMSUNG MZVL2512HCJQ-00B07 | S63CNF0T114133 | GXA7802Q | N/A       |   476 GB | GOOD   |  0.00 TB    | Windows Inbox Driver |
| 1:c    | \\.\PHYSICALDRIVE1 | SAMSUNG MZVL2512HCJQ-00B07 | S63CNF0T114205 | GXA7802Q | N/A       |   476 GB | GOOD   |  0.00 TB    | Windows Inbox Driver |
Join our user community on https://community.ovh.com/en/.
Powiązane artykuły
