Manage my Data Collector
Database di conoscenze
Icons/System/eye-open Created with Sketch. 38 viste 09.10.2018 Data Collector
This tutorial shows you how to configure your agent.
Once you have ordered an agent, you should receive several information :
  • The agent ID you just ordered
  • If necessary, your tenant ID and the password associated with it
But the agent that has been created is an empty shell and still need configuration before you can use it.
The aim of this guide is, therefore, to help you in configuring your new data collector.
Using Data Convergence API to configure your Data Collector
First, let's generate a JWT token which will be signed and contains all the claims allowing you to use certain routes and not others. By default, any new tenant can use all routes for the Data Collector API, but this might be restricted later if some endpoints are created for administration purposes, for instance.
Your JWT token is time limited to 24 hours.
1 - Generate a JWT token
  1. Navigate to https://api.dataconvergence.ovh.com Create a JWT token
  2. In the Authorization field, enter Basic followed by "your username:your password" encoded in Base64.
    • To encode in Base64, you can use the following command in Linux:
    $ echo -n 'your username:your password' | base64
    • For example using user-tutorial:password-tutorial
    $ echo -n 'user-tutorial:password-tutorial' | base64 dXNlci10dXRvcmlhbDpwYXNzd29yZC10dXRvcmlhbA==
    • Your Authorization field will thus contain Basic dXNlci10dXRvcmlhbDpwYXNzd29yZC10dXRvcmlhbA
  3. Click on Execute.
  4. In the Response Body, you should see your JWT token, generated for these credentials. Keep it somewhere to avoid having to regenerate one.
2 - List your collectors
  1. Click on the "GET /collectors" route from the "Data Collector" section. List all collectors
  2. In the Authorization field, enter "Bearer " followed by the JWT token generated in the previous step.
  3. Click on Execute and check the resulting IDs in the Response Body.
3 - Configure a data source for your Data Collector
For the next step, you need to configure a data source for your Data Collector.
  1. First, start by listing all the currently supported sources. Expand the "GET /collectors/{agentId}/sources/availableSources" List available sources
  2. Fill in the Authorization field with "Bearer " followed by the JWT token generated in the first step.
  3. Fill in the agentId field with the agent you want to configure, for example you can fill the agent ID in the result from the previous step.
  4. Click on Execute and check the response body to select the source you want to use.
  5. Here, we are going to choose to configure a "mysqlQuery" source. This source requires the following information, as specified in the previous response : List available sources
  6. Open the "POST /collectors/{agentId}/sources/{source}" route and fill in the information (Authorization as before, same for agentId and "MysqlQuery" in "source"). In the "body" field, enter the JSON data from the "MysqlQuery" JSON from the previous call:
{ "name": "your-source", "user": "your-source-user", "password": "your-source-password", "host": "your-host-ip", "port": 3306 }
  1. Then click on Execute and check the response body. It should look like this: Source result
Note that the password is not in the response for obvious security reasons
To make sure everything is okay, open the "GET /collectors/{agentId]/sources/{source}" route and fill the information (Authorization, agentId and "your-source" in "source").
Click on Execute and it should give you the resulting data: Resulting source
4 - Select sink
For the next step, you need to prepare the sink for your Data Collector. As of now, only a Kafka sink, configured by OVH, is available.
  1. To be sure that no other sinks are available, we will start by calling the "GET /collectors/{agentId}/sinks/availableSinks" route, which should give you the following response: Available sink
  2. Now, just call the "POST /collectors/{agentId}/sinks/{sink}" route with "ovhkafka" in the "sink" field and the "body" field with: { "name": "your-sink" }
  3. It should give you the following response: Sink result
  4. As for the sources, let's check the configuration of the sink (which will allow you to get data on how to read events from the Kafka queue created for you).
    Call the "GET /collectors/{agentId}/sinks/{sink}" route with the right parameters, which should give you the following response: Sink result
  5. Now you have all the necessary information to connect to your Data Collector's Kafka topic.
Deploy your agent
The last step is to deploy your agent !
Just launch the "PUT /collectors/{agentId}/deploy" and... wait for a 200 Response Body !
Your Data Collector is now configured and up and running.
If your data source is accessible, you should now see your events into Kafka !
Articoli correlati
