Sustitución del OVHgateway por un servidor dedicado (EN)
Bases de conocimiento
Icons/System/eye-open Created with Sketch. 278 visualizaciones 29.04.2025 Cloud / Nutanix on OVHcloud
An OVHgateway virtual machine is installed when deploying a Nutanix on OVHcloud cluster. This virtual machine serves as the outgoing Internet gateway for the cluster. The maximum throughput is 1 GB/s.
If you need more bandwidth, you can replace this gateway with a dedicated server and choose a solution that allows you to connect between 1 GB/s and 10 GB/s on the public network.
Contact OVHcloud Sales to help you choose the right server.
This guide explains how to replace the default gateway with an OVHcloud dedicated server to increase bandwidth.
  • A Nutanix cluster in your OVHcloud account.
  • You must be connected to the cluster via Prism Central.
  • You have a dedicated server in your OVHcloud account with several network cards, some on the public network, others on the private network. This server must be in the same data centre as the Nutanix cluster.
OVHcloud Control Panel Access
Nutanix:
  • Direct link: Nutanix
  • Navigation path: Hosted Private Cloud > Nutanix > Select your cluster
Dedicated Servers:
  • Direct link: Dedicated Servers
  • Navigation path: Bare Metal Cloud > Dedicated servers > Select your server
We will deploy a dedicated server on Linux that uses 4 network cards (2 on the public network, 2 on the private network) to replace the OVHgateway virtual machine.
To replace the OVHgateway VM, we will use these settings:
  • DHCP public LAN that provides a public address on a single network adapter
  • Private LAN on a team of two adapters and private addresses configured on a VLAN
  • VLAN 1: OVHgateway private IP address and mask (in our example: 172.16.3.254/22)
00 diagram nutanix and dedicated server 01
Retrieving information needed to deploy your server
Select your Nutanix cluster and note the name of the vRack associated with your Nutanix cluster in Private network (vRack).
01 get nutanix vrack 01
Select your dedicated server and click on Network interfaces.
02 getnetworkinformation 01
Go to the bottom right in Network interfaces and note the MAC addresses associated with the public and private networks (two MAC addresses per network).
02 getnetworkinformation 02
In the Bandwidth box, click Modify public bandwidth to change the bandwidth of your public network.
Depending on the speed you want, the price of your server subscription will increase. This change must be validated by placing a new order in the OVHcloud Control Panel.
03 Change bandwitdh 01
Select the desired bandwidth and click Next.
03 Change bandwitdh 02
Click Pay.
03 Change bandwitdh 03
Click View Purchase Order to view the purchase order.
03 Change bandwitdh 04
Once the order has been confirmed, your bandwidth will be changed.
03 Change bandwitdh 05
Connect to the vRack of the dedicated server
Stay on the configuration, click the ... button at the bottom of the page. private network adapter configuration, then click Attach a vRack Private Network.
04 attach bm to nutanix vrack 01
In the Select your private network window, select the vRack that corresponds to your Nutanix server and click Attach.
04 attach bm to nutanix vrack 02
The vRack will then be displayed in the Private network column.
04 attach bm to nutanix vrack 03
Operating system installation
We will now install a Linux Ubuntu 22 operating system from the OVH Control Panel.
Go to the menu of your dedicated server, click on the General information tab, then on the ... to the right of the field 'Last operating system (OS) installed by OVHcloud'. Click Install
05 install OS 01
Click the OS selection drop-down menu.
05 install OS 03
Select Ubuntu Server 22.04 LTS and click Next.
05 install OS 04
Click Confirm.
05 install OS 05
The operating system installation will begin. The progress window will disappear when the installation is complete.
05 install OS 06
A notification email will then be sent to the email address listed in the OVHcloud account. This email contains the administrator user account (the account is called ubuntu) and a link to get the password.
Shutting down the OVHgateway virtual machine on Prism Central
We will stop the OVHgateway virtual machine before configuring the dedicated server.
In Prism Central, go to virtual machine management. Select the virtual machine OVHgateway, go to the Actions menu and choose Guest Shutdown.
07 Shutdown ovhgateway 01
The virtual machine is then turned off.
07 Shutdown ovhgateway 02
Network configuration as Linux gateway
When deploying a Linux server from the OVHcloud Control Panel, only one network adapter is configured with the public address assigned to your server. This address will be used to log in via SSH.
Log in to your dedicated server via SSH with this command:
ssh ubuntu@dedicated-server-public-ip-address
Enter this command to display cards that are not connected.
ip a | grep -C1 DOWN
Three network adapters are displayed with the status DOWN. Go back to the list of MAC addresses and retrieve the names of the two private adapters, as in the example below:
Do not rely on the order of the cards to find the names of the private network cards, but rather on the MAC addresses referenced in the OVHcloud Control Panel.
3: "publiccardname2": <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether "mac-address-public-card2" brd ff:ff:ff:ff:ff:ff
4: "privatecardname1": <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether "mac-address-private-card1" brd ff:ff:ff:ff:ff:ff
5: "privatecardname2": <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
Launch this command:
ip a | grep -C1 UP
You will see two network adapters with status UP, the loopback adapter and a physical adapter whose MAC address must match one of the public addresses noted in the OVHcloud Control Panel. Get the name of this network adapter:
1: "lo": <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
       valid_lft forever preferred_lft forever
2: "publiccardname1": <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether "mac-address-public-card1" brd ff:ff:ff:ff:ff:ff
After you run these commands, you should have noted this information:
  • "publiccardname1": the name of the first public network adapter.
  • "mac-address-public-card1": the MAC address of the first public network adapter.
  • "privatecardname1": the name of the first private network adapter.
  • "mac-address-private-card1": the MAC address of the first private network adapter.
  • "privatecardname2": the name of the second private network adapter.
  • "mac-address-private-card2": the MAC address of the second private network adapter.
Run this command to edit the file /etc/nftables.conf
sudo nano /etc/nftables.conf
Edit the contents of the file by replacing publiccardname1 with what you have written down.
flush ruleset
define DEV_VLAN1 = bond0.1
define DEV_VLAN2 = bond0.2
define DEV_WORLD = "publiccardname1"
define NET_VLAN1 = 172.16.0.0/22
table ip global {
    chain inbound_world {
        # accepting ping (icmp-echo-request) for diagnostic purposes.
        # However, it also lets probes discover this host is alive.
        # This sample accepts them within a certain rate limit:
        # icmp type echo-request limit rate 5/second accept
        # allow SSH connections from anywhere
        ip saddr 0.0.0.0/0 tcp dport 22 accept
    chain inbound_private_vlan1 {
        # allow SSH from the VLAN1 network
        ip protocol . th dport vmap { tcp . 22 : accept}
    chain inbound {
        type filter hook input priority 0; policy drop;
        # Allow traffic from established and related packets, drop invalid
        ct state vmap { established : accept, related : accept, invalid : drop }
        # allow loopback traffic, anything else jump to chain for further evaluation
        iifname vmap { lo : accept, $DEV_WORLD : jump inbound_world, $DEV_VLAN1 : jump inbound_private_vlan1 }
        # the rest is dropped by the above policy
    chain forward {
        type filter hook forward priority 0; policy drop;
        # connections from the internal net to the internet: vlan2 to vlan1 and vlan2 to vlan1 not allowed
        meta iifname . meta oifname { $DEV_VLAN1 . $DEV_WORLD, $DEV_WORLD . $DEV_VLAN1 } accept
    chain postrouting {
        type nat hook postrouting priority 100; policy accept;
        # masquerade private IP addresses
        ip saddr $NET_VLAN1 meta oifname $DEV_WORLD counter masquerade
Run this command to edit the file /etc/netplan/50-cloud-init.yaml
sudo nano /etc/netplan/50-cloud-init.yaml
# This file is generated from information provided by the datasource.  Changes
# to it will not persist across an instance reboot.  To disable cloud-init's
# network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
    version: 2
    ethernets:
        "publiccardname1":
            accept-ra: false
            addresses:
            - 2001:41d0:20b:4500::/56
            dhcp4: true
            gateway6: fe80::1
            match:
                macaddress: "mac-address-public-card1"
            nameservers:
                addresses:
                - 2001:41d0:3:163::1
            set-name: "publiccardname1"
        #vRack interface
        "privatecardname1":
            match:
                macaddress: "mac-address-private-card1"
            optional: true
        "privatecardname2":
            match:
                macaddress: "mac-address-private-card2"
            optional: true
    bonds:
        bond0:
            dhcp4: no
            addresses: [192.168.254.2/24]
            interfaces: ["privatecardname1", "privatecardname2"]
            parameters:
                mode: 802.3ad
                transmit-hash-policy: layer3+4
    vlans:
        bond0.1:
            dhcp4: no
            dhcp6: no
            addresses: [172.16.3.254/22]
            link: bond0
Edit the contents of the /etc/netplan/50-cloud-init.yaml file by replacing the names below:
  • "publiccardname1" by the name of your public network adapter.
  • "mac-address-public-card1" by the MAC address of your public network card.
  • "privatecardname1" by the name of your first private network adapter.
  • "mac-address-private-card1" by the MAC address of your first private network card.
  • "privatecardname2" with the name of your second private network adapter.
  • "mac-address-private-card2" by the MAC address of your second private network card.
Run these commands:
apt update && apt upgrade -y
# Disable cloud-init networking
touch /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg
echo "network: {config: disabled}">> /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg
# Enable forwarding
sed -i s/#net.ipv4.ip_forward/net.ipv4.ip_forward/g /etc/sysctl.conf
sysctl net.ipv4.ip_forward
# Ufw disabling
sudo systemctl disable ufw
sudo systemctl stop ufw
# Appling network configuration
sudo netplan apply
# Nftables enabling
sudo systemctl enable nftables
sudo systemctl start nftables
# system reboot
sudo reboot
The gateway is available for the Nutanix Cluster in VLAN 1.
Test bandwidth
You can control your server's bandwidth with a tool called Iperf that you can find on Iperf's official website.
To perform a full test, create a virtual machine on Linux, install iperf3 software and run this command:
perf3 -c proof.ovh.net -p 5202 --logfile resultlog.log
Port 5202 may sometimes be unavailable. In case of difficulties, try a port between 5201 and 5210.
The test takes 10 seconds, and you will get your cluster’s bandwidth via your dedicated server.
[  6] 1796.00-1797.00 sec  1.08 GBytes  9.28 Gbits/sec    0   3.02 MBytes
[  6] 1797.00-1798.00 sec  1.08 GBytes  9.28 Gbits/sec    0   3.02 MBytes
[  6] 1798.00-1799.00 sec  1.08 GBytes  9.28 Gbits/sec    0   3.02 MBytes
[  6] 1799.00-1800.00 sec  1.08 GBytes  9.28 Gbits/sec    0   3.02 MBytes
Artículos relacionados
