Managing customer information on your WordPress websites with MainWP
Bases de conocimiento
Icons/System/eye-open Created with Sketch. 147 visualizaciones 25.01.2024 Web / Alojamiento web
Retaining customers is vital to your company’s development. Whether you have one or more websites, it’s important to get to know your customers as well as possible in order to retain and satisfy them. With the WordPress MainWP plugin, you can manage your website customers efficiently. As a CRM (Customer Relationship Management) would offer, you can add, delete and update all your customer information, for free, in just a few clicks.
This guide will show you how to manage your website’s customers’ data efficiently using MainWP.
OVHcloud provides services that you are responsible for with regard to their configuration and management. It is therefore your responsibility to ensure that they function properly.
This tutorial is designed to help you with common tasks. However, we recommend contacting a specialist provider or the publisher of the MainWP plugin if you experience any difficulties. We will not be able to assist you. More information in the "Go further" section of this tutorial.
In the MainWP main menu, click Clients. On the screen that opens, there are three tabs:
  • Customers: displays a list of all your customers
  • Add Client : allows you to create new customers
  • Client Fields: allows you to create new fields related to your customers
Add a customer
To get started, add your first customer. In the main menu of MainWP, click Clients then Add Client. In the form that appears, fill in your customer’s details. On the right-hand side of the screen, select the websites on which you want to create your new customer, then click Add Client.
mainWPClientMngt
View your customers
In the main menu of MainWP, click Clients then Clients. A list of all your customers will appear. You can search for a specific customer (in the Search field in the top right-hand corner of the table) by entering the value of one of its fields, such as its name.
mainWPClientMngt
You can drag and drop the columns of your choice to highlight the relevant information of your customers, such as the email address (column Customer Email) or the number of websites to which your customer is attached (column Websites).
From this table, you can delete any customer. Select the lines corresponding to the customers you want to delete, click Bulk actions, Delete then Apply to confirm.
mainWPClientMngt
Finally, click Yes, proceed to confirm the deletion of the customers.
In the table representing your customers, identify the customer of your choice and click on the ....
mainWPClientMngt
You can:
  • edit customer information (Edit)
  • delete the customer (Delete)
  • see the websites concerned by your customer (View Sites)
Create new fields for your customers
For each customer, many default fields are present, such as name, email, country, number or links to social networks. If you would like to add specific information that is not present by default, you can add the fields of your choice manually. In the main menu of MainWP, click Clients then Clients Fields. To create a new field, click New Field. In the window that appears, enter the name and description for your new field.
mainWPClientMngt
In our example, we create a new “loyalty” field, along with an associated description. To confirm the creation of the new field, click Save Field. Now, when creating a new customer, the new “loyalty” field will be available.
mainWPClientMngt
Once you have created your new customer, go to your customers list. Click the customer you just created. The new “loyalty” field and the corresponding value are displayed.
mainWPClientMngt
Manage multiple WordPress websites with the MainWP plugin
Improve your website's security with MainWP
Backing up your websites with MainWP
Artículos relacionados
