Install Rails on your POWER web hosting plan
Bases de conocimiento
Icons/System/eye-open Created with Sketch. 64 visualizaciones 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Ruby applications, and you want to deploy Rails on it.
Find out how to install Rails on your POWER web hosting plan.
Let's suppose you have the default configuration for Ruby hosting:
  • Runtime: Ruby 2.6
  • Entrypoint: config.ru
  • DocumentRoot: www
  • Environment: development
Be careful, Rails depends on the environment (RAILS_ENV).
Connect via SSH to your POWER web hosting.
Delete your DocumentRoot to initiate it with rails (don't forget to export your gempath or your bundle install will fail):
rm -rf www
gem env gempath
export GEM_HOME=$(gem env gempath | cut -d ':' -f1)
export RAILS_ENV=${OVH_ENVIRONMENT}
rails new www
cd www/
rails  webpacker:install
Now whitelist your domain name in www/config/environments/development.rb:
Rails.application.configure do
  # Whitelist one hostname
  config.hosts << "your-domain.ovh"
Deactivate check_yarn_integrity check under section development in www/config/webpacker.yml:
development:
  <<: *default
  compile: true
  # Verifies that correct packages and versions are installed by inspecting package.json, yarn.lock, and node_modules
  check_yarn_integrity: false
Then restart your instance and your Rails will be online.
Rails
Now let's generate a Hello World with Rails:
export SPRING_SERVER_COMMAND="$HOME/www/bin/spring server"
rails generate controller demo index
Create the template app/views/demo/index.html.erb:
vim app/views/demo/index.html.erb
&lt;h1>Hello World&lt;/h1>
&lt;p>Hello World from Rails&lt;/p>
Build the Hello World:
./bin/webpack
After another restart, your Hello World will be available in https://yourdomain.ovh/demo/index.html.
Rails
Terminal output:
~ $ rm -rf www
~ $ gem env gempath
/homez.41/powerlp/.gem/ruby/2.6.0:/usr/local/ruby2.6/lib/ruby/gems/2.6.0
~ $ export GEM_HOME=$(gem env gempath | cut -d ':' -f1)
~ $ export RAILS_ENV=${OVH_ENVIRONMENT}
~ $ rails new www
      create
      create  README.md
      create  Rakefile
      create  .ruby-version
Fetching webpacker 4.3.0
Installing webpacker 4.3.0
Bundle complete! 17 Gemfile dependencies, 75 gems now installed.
Use `bundle info [gemname]` to see where a bundled gem is installed.
         run  bundle binstubs bundler
Installing all JavaScript dependencies [4.3.0]
         run  yarn add @rails/webpacker@4.3.0 from "."
yarn add v1.22.10
├─ strip-eof@1.0.0
├─ thunky@1.1.0
├─ type-is@1.6.18
├─ unpipe@1.0.0
├─ url-parse@1.4.7
├─ utils-merge@1.0.1
├─ wbuf@1.7.3
├─ webpack-dev-middleware@3.7.3
├─ webpack-dev-server@3.11.2
├─ websocket-driver@0.7.4
├─ websocket-extensions@0.1.4
└─ ws@6.2.1
Done in 6.19s.
Webpacker successfully installed 🎉 🍰
~ $ cd www/
~/www $ rails  webpacker:install
   identical  config/webpacker.yml
Copying webpack core config
       exist  config/webpack
   identical  config/webpack/development.js
   identical  config/webpack/environment.js
   identical  config/webpack/production.js
   identical  config/webpack/test.js
info Direct dependencies
└─ webpack-dev-server@3.11.2
info All dependencies
Done in 3.81s.
~/www $ export SPRING_SERVER_COMMAND="$HOME/www/bin/spring server"
~/www $ rails generate controller demo index
Running via Spring preloader in process 11410
      create  app/controllers/demo_controller.rb
       route  get 'demo/index'
      invoke  erb
      create    app/views/demo
      create    app/views/demo/index.html.erb
      invoke  test_unit
      create    test/controllers/demo_controller_test.rb
      invoke  helper
      create    app/helpers/demo_helper.rb
      invoke    test_unit
      invoke  assets
      invoke    scss
      create      app/assets/stylesheets/demo.scss
~/www $ vim app/views/demo/index.html.erb
~/www $ ./bin/webpack
Hash: 15d1bb7b54cf6326b9ba
Version: webpack 4.44.2
Time: 1102ms
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
More information on Rails
To get more information on Rails, go to the official documentation site.
Artículos relacionados
