Install Strapi on your POWER web hosting plan
Bases de conocimiento
Icons/System/eye-open Created with Sketch. 73 visualizaciones 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Node.js applications, and you want to deploy Strapi headless CMS on it.
Find out how to install Strapi on your POWER web hosting plan.
  • Runtime: nodejs 14
  • Entrypoint: index.js
  • DocumentRoot: www
Connect via SSH to your POWER web hosting. Let's begin by cleaning the www folder and installing Strapi:
rm -rf www
npx create-strapi-app www --quickstart --no-run
Now let's go into the www folder and create the entrypoint index.js:
const strapi = require('strapi');
strapi(/* {...} */).start();
Build admin UI site :
cd www
yarn build
Create also an .htaccess file to manage HTTPS redirection:
RewriteCond %{ENV:HTTPS} !on
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
Then restart your instance and your Strapi headless CMS will be online.
Strapi
Terminal output:
 ~ $ rm -rf www
~ $ npx create-strapi-app www --quickstart --no-run
npx: 91 installed in 6.741s
Creating a new Strapi application at /home/user/www.
Creating a quickstart project.
Creating files.
Dependencies installed successfully.
~ $ cat << 'EOF' > www/index.js
EOF
~ $ cat << 'EOF' > www/.htaccess
EOF
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Artículos relacionados
