How to configure SMTP on a Load Balancer service
Bases de conocimiento
Icons/System/eye-open Created with Sketch. 75 visualizaciones 24.10.2025 Cloud / OVHcloud Load Balancer
This guide outlines how to configure the OVHcloud Load Balancer to distribute traffic across multiple SMTP servers.
  • An OVHcloud Load balancer service in your OVHcloud account.
  • A Postfix-type SMTP service installed and configured on your servers.
OVHcloud Control Panel Access
  • Direct link: Load Balancer
  • Navigation path: Network > Load Balancer > Select your service
This guide assumes a working knowledge of SMTP protocol and service operation.
As a reminder, each protocol (HTTP, TCP and UDP) in the OVHcloud Load Balancer service has its own associated front-ends, farms and servers.
The order in which elements are created is important. In particular, the server farms must be configured before servers can be attached to them.
In the Control Panel, you will see the features detailed below:
Via the OVHcloud API, use the following call:
For more information on the API features, you can refer to the following guide.
Add a server farm
A TCP server farm must be added to the service; this component manages traffic balancing across the servers.
In the Farms tab for servers, click on the +TCP/TLS button.
Fill in the fields. The mandatory fields for a basic configuration are Port and Zone. For SMTP, port 25 is used. If no ports are specified, your OVHcloud Load Balancer will automatically use the same port as the corresponding front-end.
Optionally, you can add an SMTP probe on your farm.
Add a server farm via the Control Panel
Click on Add once you have filled in the fields.
Your server farm should appear in the list, in the Farms tab.
Details of the server farm created
  • List of TCP server farms:
  • Details of a specific TCP server farm:
  • Add a new TCP server farm:
  • Modify a specific server farm:
  • Delete a specific server farm:
Add a server
A server must now be added to the server farm.
In the Farms tab, select the farm you want to add a server to by clicking on the corresponding line. The list of servers already configured in the farm will appear beneath the list of farms, along with the Add a server button. Click this button to add a new server.
The mandatory fields are the IPv4 address, Status, and ProxyProtocol version. If a server port is configured, it will override the port defined in the farm. To keep the configuration as standard as possible and easy to maintain, we recommend only using this parameter in advanced cases.
It is important to configure ProxyProtocol in version v1 so that you can retrieve the real source IP on your SMTP service. Postfix is compatible with this protocol.
Add a server to a farm.
Your server should appear in the server list, in the Farms tab, just below the list of farms.
Details of the server created.
  • List of servers in the farm:
  • Details of a specific server:
  • Add a new server:
  • Modify a specific server:
  • Delete a specific server:
Add a front-end
A front-end must now be added to the service and connected to the server farm. The front-end is the component of your OVHcloud Load Balancer that exposes your service to the internet.
Go to the + Front-ends tab, and click +TCP/TLS.
Fill in the fields. The mandatory fields for a basic configuration are Port (25 for a standard SMTP service), Zone, Default farm and Probe (if a probe was configured on your farm). If you want your service to be available across several ports at once, you can specify a list of ports, separated by commas, or a port range, in the format "-".
If you have routed Additional IPs to your OVHcloud Load Balancer service, you can also attach a front-end to one or more specific Additional IPs.
Ensure the farm you created earlier is specified as the “default farm”.
Add a front-end
Click Add once the fields are filled.
Your front-end must appear in the list, in the Front-ends tab.
Details of the front-end created
  • List of TCP front-ends:
  • Details of a specific front-end:
  • Add a new front-end:
  • Modify a specific front-end:
  • Delete a specific front-end:
Apply the modifications
Modifications made to your OVHcloud Load Balancer must be explicitly applied in each of the zones configured for your service. They will only become visible to your users at this point. This process allows for complex configuration changes to be prepared and applied only when fully ready.
If you have several zones, the same configuration must be applied to each.
Go to the homepage for the OVHcloud Load Balancer, and click Apply:Zone for each of the zones concerned.
  • Refresh a zone:
Postfix configuration
To make Postfix compatible with HAProxy ProxyProtocol, an option is required in the postfix main.cf configuration file:
smtp_upstream_proxy_protocol = haproxy
The Postfix daemon must then be restarted.
Confirmation
Upon completing these steps, you will have a functional Load Balancer service for your SMTP servers. The service status can now be checked by requesting your IP Load Balancer as an SMTP server.
Connection to SMTP via telnet
Artículos relacionados
