Configure incoming connections of an Analytics for Kafka service
Bases de conocimiento
Icons/System/eye-open Created with Sketch. 53 visualizaciones 25.08.2025 Kafka
Apache Kafka is an open-source, distributed event streaming platform designed for real-time, large-scale data processing with high scalability, durability, and low latency.
This guide explains how to configure your Kafka cluster to accept incoming connections via the OVHcloud Control Panel.
Configure the Apache Kafka service
Once your Kafka service is up and running, you will have to define at least one user and one authorised IP (if not already provided during the order) in order to fully connect to the service (as producer or consumer).
The Dashboard tab automatically updates when your service is ready.
Kafka General information
Set up a user
Switch to the Users tab. An admin user name avnadmin is preconfigured during the service installation.
Users
You can add more users by clicking the Add user button.
Add a user
Enter a username, then click Create User.
Passwords need to be reset from the Users table.
Password reset
Configure authorised IPs
For security reasons the default network configuration doesn't allow any incoming connections. It is thus critical to authorize the suitable IP addresses in order to successfully access your Kafka cluster.
If you did not define the authorised IPs during the order you can do it in the Configuration tab. At least one IP address must be authorised here before you can connect to your database.
Authorised IP
Add the IP address of your computer by using the Current IP button. You will be able to remove IPs from the table afterward.
Add IP
Your Apache Kafka service is now fully accessible! Optionally, you can configure access control lists (ACL) for granular permissions and create topics, as shown below.
We want your feedback!
Are you on Discord? Connect to our channel at https://discord.gg/ovhcloud and interact directly with the team that builds our Analytics service!
Artículos relacionados
