Technical specifications of Web Hostings
Knowledge Base
Icons/System/eye-open Created with Sketch. 5117 Views 01.04.2026 Web / Web Hosting
OVHcloud Web Hosting plans are shared. As a result, the configuration of these solutions contains certain technical specifications. We recommend that you familiarize yourself with these details before using your OVHcloud Web Hosting plan.
This guide collects some technical details about the OVHcloud Web Hosting infrastructure, based on frequently asked questions.
OVHcloud provides services for which you are responsible with regard to their configuration and management. It is therefore your responsibility to ensure that they function correctly.
This guide is designed to help you with common tasks. However, we recommend contacting a specialist provider or the software publisher if you encounter any difficulties. OVHcloud cannot provide you with technical support in this regard. You can find more information in the Go further section of this guide.
FTP
  • Use passive mode for FTP connections. Make sure that your script or FTP client is configured accordingly.
  • If you encounter the access error "530 login authentication failed" when connecting to your FTP storage space, make sure that the access information to your FTP space is correct. Please refer to our guide "Logging in to your Web Hosting plan's FTP storage space" to find all the information you need to log in to your FTP storage space. Passwords are never displayed, but they can be changed.
Emails
In order to guarantee a good quality of service on the entire shared infrastructure and thus facilitate the sending of your emails to your recipients, we apply sending quotas on our Web Hosting services.
Over a rolling period of 3600 seconds (1 hour), your Web Hosting plan will allow you to send the following email quotas:
OffersFree 100M HostingStarterPersonalProPerformance
Maximum number of emails sent per hour and per service10201002002000
These limitations apply to emails sent using the PHP mail() function only, and do not apply to other email solutions (SMTP sending).
With the exception of suspected spamming or phishing, your emails may be delayed from being sent. Your emails will be kept in a queue until the number of emails sent in the last hour is less than the quota.
In the event of abuse or proven risk, your service may be suspended (in accordance with the GTCS/Terms and Conditions of your offer) and you will be notified by email. If this is the case, consult the following guides:
Database/SQL
Simultaneous database connections
On Web Hosting plans (shared databases), there is a limit of 30 concurrent connections per database (this limit increases to 200 if you use a Web Cloud Databases offer). See the details of our Web Hosting plans to find out the options available in each Web Hosting plan.
You can also order additional Web Cloud Databases solutions, which have customization options:
  • max_connections: 100 by default, with the option of increasing to 200.
  • max_user_connections: 50 by default, with the option of increasing to 200.
To find out more, read the details of our Web Hosting plans and our guide "Getting started with your Web Cloud Databases solution".
Connections from an external server
For security reasons, it is not possible to connect from an external server to a database included in an OVHcloud Web Hosting plan. Only servers that contain OVHcloud Web Hosting plans can connect to shared database servers. Any other connection will cause the following error:
Warning: MySQL Connection Failed: Host ip.your.connection is not allowed to connect ...
Only Web Cloud Databases database servers allow external servers to connect to them. This is because you have previously authorized your external server's IP address on your database server. If necessary, please refer to our guide on "Getting started with your Web Cloud Databases solution".
Shared SQL server variables
To find out its variables, log in to your database via the PhpMyAdmin interface. Once you have logged in, click on the SQL tab at the top of the page, then enter the following query in the central form to check the MySQL server variables:
SHOW VARIABLES;
The MySQL version cannot be modified for databases included in the Web Hosting plan.
For more information on database management and connections to the phpMyAdmin interface, please refer to our guide on "Creating a database on your Web Hosting plan".
PHP
We recommend referring to our Web Hosting plans to ensure that the Web Hosting plan you want to order is right for you.
Editing the php.ini file is not available on Web Hosting plans. This is because the PHP configuration is global to the entire shared infrastructure.
However, you can modify certain elements, such as the PHP runtime environment, the runtime environment or even the PHP version of your Web Hosting plan.
Find more details on this topic in our guide on Web hosting: environment, PHP version, .ovhconfig
You can also check the configuration details for your Web Hosting plan. To do this, please read the Technical information on your Web Hosting plan section at the bottom of this guide.
PHP-FPM
PHP-FPM is enabled by default on the Web Hosting infrastructure in order to speed up PHP responses. Please note that it might not be active if you are running an older version of a Web Hosting plan which you have not upgraded (services ordered before 2014).
Some variables are different without PHP-FPM:
VariableWithout PHP-FPMWith PHP-FPM
max_execution_time120s165s
max_input_vars200016000
memory_limit128M512M
PHP scripts
Once you are connected to your hosting server via SSH, outgoing traffic will be blocked for security reasons. We therefore recommend to use PHP scripts. Please refer to our SSH guide for more information. You can consult the official PHP manual on how to execute commands and perform other tasks.
For example, you can use the function gethostbyaddr() to retrieve the hostname:
1. <?php
2. echo gethostbyaddr($_SERVER["REMOTE_ADDR"]);
3. ?>
OVHcloud does not force PHP updates on Web Hostings. Customers are fully responsible for keeping their services secure and for ensuring that any installed software is updated regularly.
Find the libraries, languages and versions available for your Web Hosting plan on this page: https://webhosting-infos.hosting.ovh.net.
For the technical specifications of the Cloud Web solution, please visit this page: https://cloudweb-infos.hosting.ovh.net/.
Automatic backup information
OVHcloud provides an automatic data backup service, as well as the provision of these backups. However, this function is non-contractual and is provided in addition to your services. It remains your responsibility to set up your own restoration policy, and to determine restore points at times you deem appropriate.
Disk space/FTP storage space
All of our Web Hosting plans located in:
  • Gravelines (GRA), France have automatic backups at D-1 / D-2 / D-3 / D-7 / D-14. These backups are also stored in the Roubaix (RBX) data centre in France.
  • Beauharnois (BHS), Canada have automatic backups on D-1 / D-2 / D-3 / D-7 / D-14. These backups are also stored in the Beauharnois (BHS) data centre in Canada.
Find out how to log in to your Web Hosting plan's FTP storage space or restore your Web Hosting plan's FTP storage space in our documentation.
Database/SQL
For shared databases (included in your Web Hosting plan) or database servers (Web Cloud Databases) offered in Gravelines (GRA), France and Beauharnois (BHS), Canada, the databases are backed up every day. These backups are accessible via the OVHcloud Control Panel or via the OVHcloud API. Backups are also stored on another infrastructure. This data is replicated in a data centre in Strasbourg (SBG). The backup retention policy is 30 days.
Find out how to Retrieve a backup of a Web Hosting plan's database in our documentation.
Email
OVHcloud provides an automatic data backup service. However, this function is non-contractual and is provided in addition to your services. It remains your responsibility to set up your own restoration policy, and to determine restore points at times you deem appropriate.
For shared email accounts (included in your Web Hosting plan), a daily automatic backup is created and copied to another data centre.
Cookies and trackers used in the provision of the Shared Hosting service.
In order to ensure the proper functioning of websites hosted on the Shared Hosting service, a "SERVER ID" cookie for those websites is placed on the end user's device. The "SERVER ID" cookie enables a service for allocating incoming traffic between the different infrastructures used for hosting the website (OVHcloud Load Balancer). It allows the user to stay on the same host server for the duration of the session. This helps to maintains and preserve the consistency of the user experience.
A "session" is defined as a given period during which a device (computer, smartphone, etc.) interacts with a server.
This helps to maintain and preserve the consistency of the user experience.
The "SERVER ID" cookie is a file stored on the end user's device that indicates the instance (server) of the infrastructure with which the user interacts. The cookie is anonymous in that no personal data of the user is processed.
The "SERVER ID" cookie is placed on the user's terminal for less than 24 hours.
This cookie type is:
  • Necessary for the operation of the Web Hosting service.
  • Anonymous.
It is therefore not liable to the prior consent of the website visitor within the meaning of the General Data Protection Regulation (GDPR).
Information about statistical tools
OVHcloud Web Statistics
OVHcloud makes available to the client statistics on website visitors and audience measurement of the website(s) hosted as part of the Hosting service(s) (hereinafter "OVHcloud Web Statistics"). OVHcloud Web Statistics helps to identify the geographical area of users of these websites, the characteristics of the devices used to access the website(s), the page views and HTTP codes. OVHcloud Web Statistics is enabled by default as part of the Shared Hosting service and can be readily disabled at the customer's request by contacting the technical support. In order to provide "OVHcloud Web Statistics", OVHcloud performs data processing.
OVHcloud Web Statistics reports are compiled from anonymised traffic data, such as the IP address and logs of users of the website, the URL of the request, the duration of the request and the "user agent".
In order to be used as part of OVHcloud Web Statistics, the aforementioned data is anonymised and aggregated using algorithms operated by OVHcloud on its own infrastructure. In particular, in order to be processed and analysed to determine the geolocation of the user (limited to a region), the IP address of the user, present in the above mentioned traffic data, is extracted in anonymised form. Thus, no personal data allowing the identification, direct or indirect, of the website users is stored as part of OVHcloud Web Statistics.
Log in to your Web Hosting plan's FTP storage space
Activating HTTPS on your website with an SSL certificate
Optimizing your website's performance
Restoring your Web Hosting plan's FTP storage space
Retrieving the backup of a Web Hosting plan's database
Related articles
