Technical capabilities and limitations of Public VCF as-a-Service
Wissensdatenbanken
Icons/System/eye-open Created with Sketch. 430 Ansichten 25.09.2025 Cloud / VMware
This guide explains the technical capabilities and limitations of Public VCF aaS (aka Public VCF as-a-Service), including resource constraints and configuration restrictions.
Before getting started, review the following guides to better understand Public VCF as-a-Service:
General limitations
ResourceStandardAdvancedPremiumComments
vCPU (per VM)323232Number of available vCPUs per VM.
RAM (per VM)128 GB128 GB128 GBMaximum RAM per VM (min. 0.5 GB).
Network Cards (per VM)101010Maximum number of network adapters per VM.
Edge Gateway (per organization)N/A55Maximum number of Edge Gateways per organization.
Public IPs (per vDC)N/A22Number of available public IPs per vDC.
Snapshots (per VM)111Maximum of 1 snapshots per VM.
VMs (per vApp)128128128Maximum number of VMs allowed per vApp.
VMs (per organization)200040004000Maximum number of VMs per organization.
vApps (per organization)10,00010,00010,000Maximum number of vApps per organization.
Segments (per organization)404040Maximum number of segments per organization.
Note: When creating a snapshot that includes the VM's memory, storage usage can quickly add up. For example, if you have 1 VM with 1 GB of RAM and a 10 GB disk, and you create a snapshot that includes memory, your storage usage will be: 10 GB (disk) + 1 GB (VM swap) + up to 10 GB (disk snapshot) + 1 GB (memory snapshot) = 22 GB total.
Hardware limitations
vCPU Frequency Min1 GHz1 GHz1 GHzIn Roadmap.
vCPU Frequency Max3 GHz3 GHz3 GHzBy Default.
Storage per VM (VMDK)1.5 TB1.5 TB1.5 TBStorage limit on VMDK.
Limitations of integration with external applications
Backup Solution
With Public VCF as-a-Service, you cannot use a backup tool other than our managed Veeam for VCD tool. Refer to the following guide for more information: Public VCF as-a-Service - Backups with Veeam Data Platform.
VMware API
Third-party products relying on vSphere APIs to function (such as Naviko, Rubrik or Zerto (non-exhaustive list)) are currently not usable within the Public VCF as-a-Service product.
Certifications
At the launch of the service, no specific certification will be applicable to the Public VCF as-a-Service by OVHcloud. However, supporting HDS, ISO27001, SOC2, or PCI-DSS certifications is one of the objectives of our roadmap.
If you need training or technical assistance to implement our solutions, please contact your Technical Account Manager or click on this link to get a quote and ask our Professional Services experts for a custom analysis of your project.
Zugehörige Artikel
