Technical capabilities
Wissensdatenbanken
Icons/System/eye-open Created with Sketch. 803 Ansichten 23.03.2023 Cloud / VMware
This page provides an overview of the technical capabilities and limitations of OVHcloud Hosted Private Cloud services.
Capabilities and known limits
ItemDescriptionValue
Max. number of PCCs per customer IDNumber of vCenters or packs per organisationNo limit
Number of linked PCCsvCenters linked (Enhanced Linked Mode)0 (not allowed)
Minimum datastores per PCC (SLA)Number of datastores per vCenter to maintain SLA2
Minimum hosts per PCC (SLA)Number of hosts per vCenter to maintain SLA2
Minimum hosts per PCC (no SLA)Bare minimum hosts to work with vCenter without SLA0
Max. number of hosts per clusterHosts per cluster64
Max. number of clusters per vDCNumber of cluster within the same virtual data centreNo limit
Max. number of vDCs per PCCVirtual data centres customers can add per vCenter400
Max. number of hosts per PCCLimits of hosts per vCenter231
Max. number of datastores per PCCLimits of datastores per vCenter110
Max. number of VMs per SDDCVMs managed by the same vCenter25000
Max. number of VMs per hostVMs hosted on the same physical host1024
Max. number of IPs per PCCMax. number of Public IPs assignable and usable per vCenter1 x /23
vCPUs, RAM and disk consumed by regular vCenterResources assigned to vCenter (VCSA)4 vCPU, 16GB RAM, 290GB Disk
vCPUs, RAM and disk consumed by regular NSXResources assigned to NSX Manager and Controller4 vCPU, 4GB RAM, 60GB Disk
4 vCPU, 2GB RAM, 28GB Disk
vCPUs, RAM and disk consumed by regular vROPSResources assigned to vROPS4 vCPU, 16GB RAM
Max. number of edge nodesMax. number of edge devices to be deployed per NSX2000
Max. number of IPSec VPN TunnelsMax. number of VPN tunnels per edge512 compact edge
1600 large edge
4096 quad large edge
6000 extra large edge
Max. number of vRack per vDCMax. number of private networks per virtual data centre1
Max. number of L2 VPN ClientsNumber of VPN clients to connect5
Max. number of whitelisted IPsNumber of IPs allowed to connect to your VMware infrastructure2048
Zugehörige Artikel
