Web Hosting - List of IP addresses by cluster
Knowledge Base
Icons/System/eye-open Created with Sketch. 1701 Views 23.02.2026 Web / Web Hosting
In this guide you can find all of the IP addresses for OVHcloud web hosting plans. For example, you can use it to find the IP address you need to enter in your DNS zones, depending on:
  • Your cluster/hosting
  • Your options (CDN, paid SSL, free SSL, etc.)
  • The targeted country
This guide lists all available IP addresses of OVHcloud Web Hosting plans, sorted by clusters.
Please note that the IP addresses of the CDN options are "Anycast", meaning they do not need geolocalisation (see also the product page).
OVHcloud Control Panel Access
  • Direct link: Hosting plans
  • Navigation path: Web Cloud > Hosting plans > Select your web hosting plan
To find out on which web hosting cluster your service is located, click on the tabs below to view each of the 2 steps.
Go to the Hosting plans page, then select the web hosting plan concerned.
Web Hosting
In the General information box on the page that appears, retrieve the cluster number under the mention Cluster (3 digits between 0 and 9).
Cluster and Filer number
Click below on the cluster number where your web hosting is located to display the corresponding IP addresses.
Cluster 024
Cluster IP addresses per country
CountryCountry CodeIPv4IPv6
FranceFR188.165.61.822001:41d0:301::24
IrelandIE188.165.6.812001:41d0:301:3::24
PortugalPT5.135.68.672001:41d0:301:2::24
United KingdomUK178.32.59.1942001:41d0:301:12::24
ItalyIT178.32.140.1722001:41d0:301:11::24
SpainES51.255.132.412001:41d0:301:4::24
PolandPL94.23.88.1052001:41d0:301:5::24
Czech RepublicCZ94.23.169.752001:41d0:301:6::24
NetherlandsNL94.23.149.142001:41d0:301:7::24
FinlandFI188.165.138.22001:41d0:301:8::24
LithuaniaLT164.132.150.732001:41d0:301:9::24
GermanyDE178.33.38.882001:41d0:301:1::24
BelgiumBE213.32.81.1032001:41d0:301:10::24
If you have activated the Shared CDN option on your Web Hosting, use this IP address:
46.105.204.24
If you need the outgoing IP address of the Web Hosting cluster (gateway), use this IP address:
91.134.248.230
Cluster 100
FranceFR5.135.23.1642001:41d0:301::100
IrelandIE188.165.0.1432001:41d0:301:3::100
PortugalPT94.23.76.762001:41d0:301:2::100
United KingdomUK87.98.254.1872001:41d0:301:12::100
ItalyIT178.32.143.1652001:41d0:301:11::100
SpainES178.33.119.2112001:41d0:301:4::100
PolandPL94.23.89.1162001:41d0:301:5::100
Czech RepublicCZ94.23.172.2262001:41d0:301:6::100
NetherlandsNL94.23.146.2442001:41d0:301:7::100
FinlandFI188.165.137.372001:41d0:301:8::100
LithuaniaLT188.165.26.1522001:41d0:301:9::100
GermanyDE87.98.243.1772001:41d0:301:1::100
BelgiumBE91.121.217.512001:41d0:301:10::100
46.105.204.100
54.36.142.130
Cluster 102
FranceFR213.186.33.22001:41d0:1:1b00:213:186:33:2
IrelandIE188.165.7.22001:41d0:1:1b00:188:165:7:2
PortugalPT94.23.79.22001:41d0:1:1b00:94:23:79:2
United KingdomUK87.98.255.22001:41d0:1:1b00:87:98:255:2
ItalyIT94.23.64.22001:41d0:1:1b00:94:23:64:2
SpainES87.98.231.22001:41d0:1:1b00:87:98:231:2
PolandPL87.98.239.22001:41d0:1:1b00:87:98:239:2
Czech RepublicCZ94.23.175.22001:41d0:1:1b00:94:23:175:2
NetherlandsNL94.23.151.22001:41d0:1:1b00:94:23:151:2
FinlandFI188.165.143.22001:41d0:1:1b00:188:165:143:2
LithuaniaLT188.165.31.22001:41d0:1:1b00:188:165:31:2
GermanyDE87.98.247.22001:41d0:1:1b00:87:98:247:2
46.105.204.2
5.39.29.130
Cluster 103
FranceFR213.186.33.42001:41d0:1:1b00:213:186:33:4
IrelandIE188.165.7.42001:41d0:1:1b00:188:165:7:4
PortugalPT94.23.79.42001:41d0:1:1b00:94:23:79:4
United KingdomUK87.98.255.42001:41d0:1:1b00:87:98:255:4
ItalyIT94.23.64.42001:41d0:1:1b00:94:23:64:4
SpainES87.98.231.42001:41d0:1:1b00:87:98:231:4
PolandPL87.98.239.42001:41d0:1:1b00:87:98:239:4
Czech RepublicCZ94.23.175.42001:41d0:1:1b00:94:23:175:4
NetherlandsNL94.23.151.42001:41d0:1:1b00:94:23:151:4
FinlandFI188.165.143.42001:41d0:1:1b00:188:165:143:4
LithuaniaLT188.165.31.42001:41d0:1:1b00:188:165:31:4
GermanyDE87.98.247.42001:41d0:1:1b00:87:98:247:4
46.105.204.3
5.135.52.162
Cluster 105
FranceFR213.186.33.162001:41d0:1:1b00:213:186:33:16
IrelandIE188.165.7.162001:41d0:1:1b00:188:165:7:16
PortugalPT94.23.79.162001:41d0:1:1b00:94:23:79:16
United KingdomUK87.98.255.162001:41d0:1:1b00:87:98:255:16
ItalyIT94.23.64.162001:41d0:1:1b00:94:23:64:16
SpainES87.98.231.162001:41d0:1:1b00:87:98:231:16
PolandPL87.98.239.162001:41d0:1:1b00:87:98:239:16
Czech RepublicCZ94.23.175.162001:41d0:1:1b00:94:23:175:16
NetherlandsNL94.23.151.162001:41d0:1:1b00:94:23:151:16
FinlandFI188.165.143.162001:41d0:1:1b00:188:165:143:16
LithuaniaLT188.165.31.162001:41d0:1:1b00:188.165.31.16
GermanyDE87.98.247.162001:41d0:1:1b00:87:98:247:16
46.105.204.5
5.135.37.162
Cluster 106
FranceFR213.186.33.172001:41d0:1:1b00:213:186:33:17
IrelandIE188.165.7.172001:41d0:1:1b00:188:165:7:17
PortugalPT94.23.79.172001:41d0:1:1b00:94:23:79:17
United KingdomUK87.98.255.172001:41d0:1:1b00:87:98:255:17
ItalyIT94.23.64.172001:41d0:1:1b00:94:23:64:17
SpainES87.98.231.172001:41d0:1:1b00:87:98:231:17
PolandPL87.98.239.172001:41d0:1:1b00:87:98:239:17
Czech RepublicCZ94.23.175.172001:41d0:1:1b00:94:23:175:17
NetherlandsNL94.23.151.172001:41d0:1:1b00:94:23:151:17
FinlandFI188.165.143.172001:41d0:1:1b00:188:165:143:17
LithuaniaLT188.165.31.172001:41d0:1:1b00:188:165:31:17
GermanyDE87.98.247.172001:41d0:1:1b00:87:98:247:17
46.105.204.6
5.135.47.98
Cluster 107
FranceFR213.186.33.182001:41d0:1:1b00:213:186:33:18
IrelandIE188.165.7.182001:41d0:1:1b00:188:165:7:18
PortugalPT94.23.79.182001:41d0:1:1b00:94:23:79:18
United KingdomUK87.98.255.182001:41d0:1:1b00:87:98:255:18
ItalyIT94.23.64.182001:41d0:1:1b00:94:23:64:18
SpainES87.98.231.182001:41d0:1:1b00:87:98:231:18
PolandPL87.98.239.182001:41d0:1:1b00:87:98:239:18
Czech RepublicCZ94.23.175.182001:41d0:1:1b00:94:23:175:18
NetherlandsNL94.23.151.182001:41d0:1:1b00:94:23:151:18
FinlandFI188.165.143.182001:41d0:1:1b00:188:165:143:18
LithuaniaLT188.165.31.182001:41d0:1:1b00:188:165:31:18
GermanyDE87.98.247.182001:41d0:1:1b00:87:98:247:18
46.105.204.7
5.135.52.18
Cluster 110
FranceFR213.186.33.192001:41d0:1:1b00:213:186:33:19
IrelandIE188.165.7.192001:41d0:1:1b00:188:165:7:19
PortugalPT94.23.79.192001:41d0:1:1b00:94:23:79:19
United KingdomUK87.98.255.192001:41d0:1:1b00:87:98:255:19
ItalyIT94.23.64.192001:41d0:1:1b00:94:23:64:19
SpainES87.98.231.192001:41d0:1:1b00:87:98:231:19
PolandPL87.98.239.192001:41d0:1:1b00:87:98:239:19
Czech RepublicCZ94.23.175.192001:41d0:1:1b00:94:23:175:19
NetherlandsNL94.23.151.192001:41d0:1:1b00:94:23:151:19
FinlandFI188.165.143.192001:41d0:1:1b00:188:165:143:19
LithuaniaLT188.165.31.192001:41d0:1:1b00:188:165:31:19
GermanyDE87.98.247.192001:41d0:1:1b00:87:98:247:19
46.105.204.10
5.135.39.194
Cluster 111
FranceFR213.186.33.402001:41d0:1:1b00:213:186:33:40
IrelandIE188.165.7.402001:41d0:1:1b00:188:165:7:40
PortugalPT94.23.79.402001:41d0:1:1b00:94:23:79:40
United KingdomUK87.98.255.402001:41d0:1:1b00:87:98:255:40
ItalyIT94.23.64.402001:41d0:1:1b00:94:23:64:40
SpainES87.98.231.402001:41d0:1:1b00:87:98:231:40
PolandPL87.98.239.402001:41d0:1:1b00:87:98:239:40
Czech RepublicCZ94.23.175.402001:41d0:1:1b00:94:23:175:40
NetherlandsNL94.23.151.402001:41d0:1:1b00:94:23:151:40
FinlandFI188.165.143.402001:41d0:1:1b00:188:165:143:40
LithuaniaLT188.165.31.402001:41d0:1:1b00:188:165:31:40
GermanyDE87.98.247.402001:41d0:1:1b00:87:98:247:40
46.105.204.11
5.135.38.50
Cluster 112
FranceFR213.186.33.482001:41d0:1:1b00:213:186:33:48
IrelandIE188.165.7.482001:41d0:1:1b00:188:165:7:48
PortugalPT94.23.79.482001:41d0:1:1b00:94:23:79:48
United KingdomUK87.98.255.482001:41d0:1:1b00:87:98:255:48
ItalyIT94.23.64.482001:41d0:1:1b00:94:23:64:48
SpainES87.98.231.482001:41d0:1:1b00:87:98:231:48
PolandPL87.98.239.482001:41d0:1:1b00:87:98:239:48
Czech RepublicCZ94.23.175.482001:41d0:1:1b00:94:23:175:48
NetherlandsNL94.23.151.482001:41d0:1:1b00:94:23:151:48
FinlandFI188.165.143.482001:41d0:1:1b00:188:165:143:48
LithuaniaLT188.165.31.482001:41d0:1:1b00:188:165:31:48
GermanyDE87.98.247.482001:41d0:1:1b00:87:98:247:48
46.105.204.12
5.39.53.162
Cluster 113
FranceFR213.186.33.242001:41d0:1:1b00:213:186:33:24
IrelandIE188.165.7.242001:41d0:1:1b00:188:165:7:24
PortugalPT94.23.79.242001:41d0:1:1b00:94:23:79:24
United KingdomUK87.98.255.242001:41d0:1:1b00:87:98:255:24
ItalyIT94.23.64.242001:41d0:1:1b00:94:23:64:24
SpainES87.98.231.242001:41d0:1:1b00:87:98:231:24
PolandPL87.98.239.242001:41d0:1:1b00:87:98:239:24
Czech RepublicCZ94.23.175.242001:41d0:1:1b00:94:23:175:24
NetherlandsNL94.23.151.242001:41d0:1:1b00:94:23:151:24
FinlandFI188.165.143.242001:41d0:1:1b00:188:165:143:24
LithuaniaLT188.165.31.242001:41d0:1:1b00:188:165:31:24
GermanyDE87.98.247.242001:41d0:1:1b00:87:98:247:24
46.105.204.13
5.135.39.18
Cluster 114
FranceFR213.186.33.872001:41d0:1:1b00:213:186:33:87
IrelandIE188.165.7.872001:41d0:1:1b00:188:165:7:87
PortugalPT94.23.79.872001:41d0:1:1b00:94:23:79:87
United KingdomUK87.98.255.872001:41d0:1:1b00:87:98:255:87
ItalyIT94.23.64.872001:41d0:1:1b00:94:23:64:87
SpainES87.98.231.872001:41d0:1:1b00:87:98:231:87
PolandPL87.98.239.872001:41d0:1:1b00:87:98:239:87
Czech RepublicCZ94.23.175.872001:41d0:1:1b00:94:23:175:87
NetherlandsNL94.23.151.872001:41d0:1:1b00:94:23:151:87
FinlandFI188.165.143.872001:41d0:1:1b00:188:165:143:87
LithuaniaLT188.165.31.872001:41d0:1:1b00:188:165:31:87
GermanyDE87.98.247.872001:41d0:1:1b00:87:98:247:87
46.105.204.14
5.135.42.162
Cluster 115
FranceFR213.186.33.32001:41d0:1:1b00:213:186:33:3
IrelandIE188.165.7.32001:41d0:1:1b00:188:165:7:3
PortugalPT94.23.79.32001:41d0:1:1b00:94:23:79:3
United KingdomUK87.98.255.32001:41d0:1:1b00:87:98:255:3
ItalyIT94.23.64.32001:41d0:1:1b00:94:23:64:3
SpainES87.98.231.32001:41d0:1:1b00:87:98:231:3
PolandPL87.98.239.32001:41d0:1:1b00:87:98:239:3
Czech RepublicCZ94.23.175.32001:41d0:1:1b00:94:23:175:3
NetherlandsNL94.23.151.32001:41d0:1:1b00:94:23:151:3
FinlandFI188.165.143.32001:41d0:1:1b00:188:165:143:3
LithuaniaLT188.165.31.32001:41d0:1:1b00:188:165:31:3
GermanyDE87.98.247.32001:41d0:1:1b00:87:98:247:3
46.105.204.15
5.135.41.162
Cluster 117
FranceFR213.186.33.502001:41d0:1:1b00:213:186:33:50
IrelandIE188.165.7.502001:41d0:1:1b00:188:165:7:50
PortugalPT94.23.79.502001:41d0:1:1b00:94:23:79:50
United KingdomUK87.98.255.502001:41d0:1:1b00:87:98:255:50
ItalyIT94.23.64.502001:41d0:1:1b00:94:23:64:50
SpainES87.98.231.502001:41d0:1:1b00:87:98:231:50
PolandPL87.98.239.502001:41d0:1:1b00:87:98:239:50
Czech RepublicCZ94.23.175.502001:41d0:1:1b00:94:23:175:50
NetherlandsNL94.23.151.502001:41d0:1:1b00:94:23:151:50
FinlandFI188.165.143.502001:41d0:1:1b00:188:165:143:50
LithuaniaLT188.165.31.502001:41d0:1:1b00:188:165:31:50
GermanyDE87.98.247.502001:41d0:1:1b00:87:98:247:50
46.105.204.17
5.135.50.34
Cluster 120
FranceFR46.105.57.1692001:41d0:301::20
IrelandIE51.254.78.2272001:41d0:301:3::20
PortugalPT5.135.59.602001:41d0:301:2::20
United KingdomUK51.254.94.1832001:41d0:301:12::20
ItalyIT37.59.236.1562001:41d0:301:11::20
SpainES37.59.203.1112001:41d0:301:4::20
PolandPL178.32.149.1852001:41d0:301:5::20
Czech RepublicCZ51.254.181.432001:41d0:301:6::20
NetherlandsNL37.59.164.2052001:41d0:301:7::20
FinlandFI5.196.208.1172001:41d0:301:8::20
LithuaniaLT5.196.129.522001:41d0:301:9::20
GermanyDE5.135.108.2192001:41d0:301:1::20
BelgiumBE5.196.203.2002001:41d0:301:10::20
46.105.204.20
5.135.48.162
Cluster 121
FranceFR188.165.53.1852001:41d0:301::21
IrelandIE188.165.6.202001:41d0:301:6::21
PortugalPT94.23.75.2352001:41d0:301:2::21
United KingdomUK94.23.152.2202001:41d0:301:12::21
ItalyIT94.23.69.2272001:41d0:301:11::21
SpainES87.98.230.2412001:41d0:301:4::21
PolandPL188.165.23.192001:41d0:301:5::21
Czech RepublicCZ94.23.173.1842001:41d0:301:6::21
NetherlandsNL94.23.144.602001:41d0:301:7::21
FinlandFI188.165.139.2192001:41d0:301:8::21
LithuaniaLT188.165.30.412001:41d0:301:9::21
GermanyDE94.23.162.92001:41d0:301:1::21
BelgiumBE178.32.40.722001:41d0:301:10::21
46.105.204.21
5.135.48.114
Cluster 123
FranceFR164.132.235.172001:41d0:301::23
IrelandIE79.137.112.242001:41d0:301:3::23
PortugalPT5.135.68.662001:41d0:301:2::23
United KingdomUK178.32.59.1502001:41d0:301:12::23
ItalyIT178.32.140.1712001:41d0:301:11::23
SpainES51.254.16.362001:41d0:301:4::23
PolandPL87.98.235.1842001:41d0:301:5::23
Czech RepublicCZ94.23.169.832001:41d0:301:6::23
NetherlandsNL94.23.148.1872001:41d0:301:7::23
FinlandFI178.32.17.2462001:41d0:301:8::23
LithuaniaLT37.59.69.1222001:41d0:301:9::23
GermanyDE87.98.242.652001:41d0:301:1::23
BelgiumBE137.74.229.682001:41d0:301:10::23
46.105.204.23
5.135.41.82
Cluster 126
FranceFR87.98.154.1462001:41d0:301::26
IrelandIE188.165.4.352001:41d0:301:3::26
PortugalPT51.254.64.1072001:41d0:301:2::26
United KingdomUK91.134.201.1122001:41d0:301:12::26
ItalyIT94.23.66.2122001:41d0:301:11::26
SpainES188.165.129.1452001:41d0:301:4::26
PolandPL178.32.205.962001:41d0:301:5::26
Czech RepublicCZ137.74.234.2112001:41d0:301:6::26
NetherlandsNL137.74.180.1172001:41d0:301:7::26
FinlandFI137.74.48.1192001:41d0:301:8::26
LithuaniaLT188.165.29.1262001:41d0:301:9::26
GermanyDE94.23.160.292001:41d0:301:1::26
BelgiumBE178.32.43.462001:41d0:301:10::26
46.105.204.26
5.135.42.226
Cluster 127
FranceFR54.36.91.622001:41d0:301::27
IrelandIE54.36.31.1452001:41d0:301:3::27
PortugalPT193.70.24.822001:41d0:301:2::27
United KingdomUK54.36.203.1652001:41d0:301:12::27
ItalyIT178.32.138.2122001:41d0:301:11::27
SpainES213.32.37.2332001:41d0:301:4::27
PolandPL178.32.203.1252001:41d0:301:5::27
Czech RepublicCZ54.37.182.2302001:41d0:301:6::27
NetherlandsNL54.36.41.832001:41d0:301:7::27
FinlandFI188.165.140.1942001:41d0:301:8::27
LithuaniaLT51.255.97.182001:41d0:301:9::27
GermanyDE91.134.179.2512001:41d0:301:1::27
BelgiumBE193.70.58.2262001:41d0:301:10::27
46.105.204.27
5.135.54.114
Cluster 128
FranceFR51.91.236.1932001:41d0:301::28
IrelandIE92.222.139.1902001:41d0:301:3::28
PortugalPT217.182.39.2512001:41d0:301:2::28
United KingdomUK193.70.71.1492001:41d0:301:12::28
ItalyIT51.255.117.2022001:41d0:301:11::28
SpainES54.36.145.1732001:41d0:301:4::28
PolandPL213.32.10.1112001:41d0:301:5::28
Czech RepublicCZ54.38.116.1142001:41d0:301:6::28
NetherlandsNL176.31.23.1912001:41d0:301:7::28
FinlandFI51.255.135.352001:41d0:301:8::28
LithuaniaLT51.83.29.1352001:41d0:301:9::28
GermanyDE54.37.173.1272001:41d0:301:1::28
BelgiumBE193.70.70.1442001:41d0:301:10::28
46.105.204.28
5.135.37.210
Cluster 129
FranceFR51.91.236.2552001:41d0:301::29
IrelandIE92.222.139.1562001:41d0:301:3::29
PortugalPT46.105.159.2202001:41d0:301:2::29
United KingdomUK178.32.48.1092001:41d0:301:12::29
ItalyIT178.32.137.1392001:41d0:301:11::29
SpainES188.165.132.1442001:41d0:301:4::29
PolandPL213.32.10.2052001:41d0:301:5::29
Czech RepublicCZ5.196.248.552001:41d0:301:6::29
NetherlandsNL51.83.124.42001:41d0:301:7::29
FinlandFI79.137.116.1292001:41d0:301:8::29
LithuaniaLT164.132.14.1172001:41d0:301:9::29
GermanyDE145.239.222.452001:41d0:301:1::29
BelgiumBE178.32.44.1402001:41d0:301:10::29
46.105.204.29
5.135.48.82
Cluster 130
FranceFR145.239.37.1622001:41d0:301::30
IrelandIE178.32.77.1132001:41d0:301:3::30
PortugalPT5.135.68.912001:41d0:301:2::30
United KingdomUK91.134.177.2282001:41d0:301:12::30
ItalyIT94.23.73.162001:41d0:301:11::30
SpainES149.202.105.2282001:41d0:301:4::30
PolandPL188.165.21.82001:41d0:301:5::30
Czech RepublicCZ94.23.168.1432001:41d0:301:6::30
NetherlandsNL149.202.25.752001:41d0:301:7::30
FinlandFI188.165.140.1512001:41d0:301:8::30
LithuaniaLT188.165.24.1462001:41d0:301:9::30
GermanyDE51.255.232.792001:41d0:301:1::30
BelgiumBE213.32.107.2412001:41d0:301:10::30
46.105.204.30
5.135.43.82
Cluster 131
FranceFR146.59.209.1522001:41d0:301::31
IrelandIE188.165.5.1072001:41d0:301:3::31
PortugalPT51.178.229.472001:41d0:301:2::31
United KingdomUK178.32.52.1772001:41d0:301:12::31
ItalyIT94.23.66.842001:41d0:301:11::31
SpainES51.255.26.632001:41d0:301:4::31
PolandPL87.98.236.2532001:41d0:301:5::31
Czech RepublicCZ217.182.52.812001:41d0:301:6::31
NetherlandsNL213.32.108.832001:41d0:301:7::31
FinlandFI178.32.10.722001:41d0:301:8::31
LithuaniaLT188.165.30.1822001:41d0:301:9::31
GermanyDE151.80.4.2192001:41d0:301:1::31
BelgiumBE217.182.187.172001:41d0:301:10::31
46.105.204.31
5.135.42.194
Cluster 151
CanadaCA51.161.122.782607:5300:202:0:0::51
46.105.204.51
15.235.26.178
Hosting multiple websites on your Web Hosting plan
Activating HTTPS on your website with an SSL certificate
Optimise your website’s performance
Related articles
