Cloud Archive Swift - Creating a Public Cloud Archive container
Knowledge Base
Icons/System/eye-open Created with Sketch. 580 Views 27.10.2021 Cloud / Object Storage S3
The Public Cloud Archive offer is an unlimited storage solution with simple billing tailored to your needs. There are many types of object containers:
  • For static hosting (static website).
  • For private hosting (e.g. storage of personal data).
  • For public hosting (to store everything that is accessible to the public).
  • For cold storage (archiving).
The first step is to create a container that will hold your files.
This guide explains how to create a container in the OVHcloud Control Panel.
OVHcloud Control Panel Access
Creating a Public Cloud Archive container from the customer area
Click on Cloud Archive in the left-hand navigation bar under "Storage". If this is your first container :
pca dashboard
If this is not your first container:
pca dashboard
Select the region of your container, then click Next :
select a region
Name your container, then click Create the container :
If you want to link your container to a domain name, your container name must not contain the following characters:
  • [ _ ]
  • And you must not use capital letters.
Refer to our guide on linking a container to a domain name if necessary.
container name
Your container is now created:
container created
Related articles
