Configuring a TERMINATED_HTTPS listener via CLI / Horizon
Knowledge Base
Icons/System/eye-open Created with Sketch. 233 Views 24.12.2024 Cloud / Network Gateway for Public Cloud
Our Public Cloud Load Balancer is based on OpenStack Octavia and is fully integrated into the Public Cloud universe.
After setting up your Load Balancer, you can configure it with a certificate in order to process HTTPS connections.
This tutorial explains how to configure a secure Public Cloud Load Balancer.
If you are not yet familiar with creating a Load Balancer, please follow our guide on Getting started with Load Balancer on Public Cloud before you continue with this tutorial.
OVHcloud Control Panel Access
Attaching a Floating IP address to a Load Balancer
You can find the instructions for this part in this documentation in the section bearing the same name.
Preparing the certificate
For this stage, we need a certificate, which has already been generated.
When your certificate is generated by your supplier, you generally receive 2 or 3 files, described as follows:
  • Main certificate (.crt or .pem file).
  • Private key (.key file) generated during the CSR request.
  • Intermediate certificate or complete chain (.crt file), if supplied. Some suppliers already include the intermediate chain in the main certificate, in which case you will only receive 2 files.
If you have obtained 3 files, you will need to merge the main certificate with the intermediate certificate to create a complete certificate. If your supplier already provides a complete certificate incorporating the intermediate chain, this merging step should be omitted.
sudo cat <certificate.crt> <intermediate_chain.crt> > main_certificate.pem
You need to create a PKCS#12 package with your certificate inside:
sudo openssl pkcs12 -export -inkey <private_key.key> -in <main_certificate.pem> -out domain.tld.p12
You must download this file directly onto your computer in order to be able to send it to Openstack Barbican (‘Secret as a Service’).
openstack secret store --name='cert-domain.tld' -t 'application/octet-stream' -e 'base64' --payload="$(base64 < domain.tld.p12)"
Configuring your Load Balancer
Via Horizon
In the Horizon interface, open the Network section, then click Load Balancers
Select your Load Balancer by clicking on it.
Next, click on the Listeners tab, then on Create Listener:
listeners list
Listener Details
listener creation details section
InformationDetails
NameSpecify a name for your listener.
ProtocolSelect the HTTP protocol
PortSelect 80
Pool Details
listener creation pool section
Under ‘Create Pool’, click No, then at the bottom, click on Create Listener.
Once the listener has been created, click on it. Next, click on the L7 policies tab, then on Create L7 Policy.
l7policy creation
L7 Policy Details
l7policy creation
InformationDetails
NameSpecify a name for your L7 Policy
Actionchoose the value REDIRECT_TO_URL
Redirect URLEnter the domain name
Once done, click on Create L7 policy.
Via the OpenStack API or via the OVHcloud Control Panel
To create a listener via the OpenStack API or via the OVHcloud Control Panel you can consult the relevant section in this guide, in the ‘Configuring your Load Balancer’ section.
Then configure the redirection of HTTP requests to HTTPS:
openstack loadbalancer l7policy create --action REDIRECT_TO_URL --redirect-url https://<your-domain-or-ip> --name redirect-to-https http-listener
Configuring the secure Listener on the Load Balancer
Now that you have managed your certificate, you can add a secure Listener and associate a pool and its members with it:
Via Horizon
In the Horizon interface, open the Network section, then click on Load Balancers.
You can now click on the Listeners section, then on Create Listener as follows:
listeners list
Listener Details
listeners https details
InformationDetails
ProtocolSelect the TERMINATED_HTTPS protocol
PortSelect 443
Pool Details
listeners https pool details
Under ‘Create Pool’ select Yes.
Choose a name for your Pool, in the ‘Algortihm’ field, choose the value ROUND_ROBIN and select Yes under ‘TLS Enabled’.
Pool Members
listeners https pool members details
Select the corresponding instance and click on Add. Once this has been done, select port 80. as the ‘Port’.
Monitor Details
We're going to select No as we won't be demonstrating this part in this guide.
SSL Certificates
listeners https ssl details
Select the certificate that was previously added to Openstack Barbican, in this section.
Once done, click on Create Listener to create your configured Load Balancer.
openstack loadbalancer listener create --protocol-port 443 --protocol TERMINATED_HTTPS --name https-listener --default-tls-container=$(openstack secret list | awk '/ cert-domain.tld / {print $2}') my_load_balancer
openstack loadbalancer pool create --name pool-tls --lb-algorithm ROUND_ROBIN --listener https-listener --protocol HTTP
openstack loadbalancer member create --subnet-id my_subnet --address <private_ip_instance> --protocol-port 80 pool-tls
You can now access your Load Balancer securely. However, you will need to renew your certificate. Check the renewal policy with your certificate provider.
Official documentation of OpenStack Octavia
Cookbook OpenStack Octavia
Related articles
