Configuring a secure Load Balancer with Let's Encrypt
Knowledge Base
Icons/System/eye-open Created with Sketch. 1228 Views 06.11.2023 Cloud / Network Gateway for Public Cloud
Our Public Cloud Load Balancer is based on OpenStack Octavia and is fully integrated into the Public Cloud universe.
After setting up your Load Balancer, you can configure it with a certificate in order to process HTTPS connections.
This tutorial explains how to configure a secure Public Cloud Load Balancer with Let's Encrypt.
If you are not yet familiar with creating a Load Balancer, please follow our guide on Getting started with Load Balancer on Public Cloud before you continue with this tutorial.
Creating an instance for Let's Encrypt
You can create an instance in your project in the region where your Load Balancer is located. Read about the details in our guide if necessary. The d2-2 instance type will be sufficient for this operation. We recommend that you use Ubuntu as your operating system.
Once you have created your instance, you can refer to the Let's Encrypt documentation to install Certbot.
Attaching a Floating IP address to a Load Balancer
This is how to attach a Floating IP address to a Load Balancer:
openstack floating ip create Ext-Net
openstack floating ip set --port <my_load_balancer_vip_port_id> <floating_ip>
To retrieve the VIP port ID of your Load Balancer, use openstack loadbalancer show my_load_balancer.
Please note that you must add an A record in the DNS Zone of your domain name that points to the Floating IP.
If you are using DNS servers managed by OVHcloud, please consult this guide.
Configuring your Load Balancer
In this step, create a first Listener which will listen on port 80 (HTTP) and will take care of redirecting HTTP to HTTPS. It will also contain a redirection rule to the Let's Encrypt instance for certificate verification.
openstack loadbalancer listener create --protocol-port 80 --protocol HTTP --name http-listener my_load_balancer
openstack loadbalancer pool create --name pool-letsencrypt --lb-algorithm ROUND_ROBIN --listener http-listener --protocol HTTP
openstack loadbalancer member create --subnet-id my_subnet --address <private_ip_letsencrypt_instance>  --protocol-port 80 pool-letsencrypt
We will now create the redirection rules:
openstack loadbalancer l7policy create --action REDIRECT_TO_POOL --redirect-pool pool-letsencrypt --name letsencrypt-redirection http-listener --position 1
openstack loadbalancer l7rule create --compare-type STARTS_WITH --type PATH --value /.well-known/acme-challenge letsencrypt-redirection
Generating a certificate
From the Let's Encrypt instance, you can now launch the certificate generation.
ubuntu@letsencrypt:~$ sudo certbot certonly -d <domain.tld> --standalone -m <email> --agree-tos
Once the process is completed, your certificate will be located in /etc/letsencrypt/live/domain.tld. You will then need to merge the certificate with its certificate private key:
ubuntu@letsencrypt:~$ sudo cat /etc/letsencrypt/live/domain.tld/fullchain.pem /etc/letsencrypt/live/domain.tld/privkey.pem | sudo tee /etc/ssl/domain.tld.pem
Now that you have your certificate, you can add a Secure Listener and associate a pool and its members with it :
ubuntu@letsencrypt:~$ sudo openssl pkcs12 -export -inkey /etc/ssl/domain.tld.pem -in /etc/ssl/domain.tld.pem -out /etc/ssl/domain.tld.p12
You have to download this file directly to your local device in order to send it to OpenStack Barbican ("Secret as a Service").
openstack secret store --name='LetsEncrypt-cert-domain.tld' -t 'application/octet-stream' -e 'base64' --payload="$(base64 < domain.tld.p12)"
Configuring the secure Listener on the Load Balancer
With your certificate now created, you can add a secure Listener:
openstack loadbalancer listener create --protocol-port 443 --protocol TERMINATED_HTTPS --name https-listener --default-tls-container=$(openstack secret list | awk '/ LetsEncrypt-cert-domain.tld / {print $2}') my_load_balancer
openstack loadbalancer pool create --name pool-tls --lb-algorithm ROUND_ROBIN --listener https-listener --protocol HTTP
openstack loadbalancer member create --subnet-id my_subnet --address <private_ip_instance_1> --protocol-port 80 pool-tls
openstack loadbalancer member create --subnet-id my_subnet --address <private_ip_instance_2> --protocol-port 80 pool-tls
You can now securely access your Load Balancer with Let's Encrypt. Be careful, you will need to renew the certificate every 3 months.
Official documentation of OpenStack Octavia
Cookbook OpenStack Octavia
Related articles
