Install a real-time presentation slide platform on your POWER web hosting plan
Knowledge Base
Icons/System/eye-open Created with Sketch. 296 Views 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Node.js applications, and you want to deploy a real-time presentation slide platform on it.
Find out how to install Slideshow on your POWER web hosting plan.
  • Runtime: nodejs 14
  • Entrypoint: index.js
  • DocumentRoot: www
Connect via SSH to your POWER web hosting. Let's begin by retrieving the sources of the project:
rm -rf www
git clone https://github.com/nafeu/realtime-slides-tut.git www
Now let's go into the www folder, do an npm install and symlink the entrypoint to the application main file:
cd www
npm install --save
ln -fs server.js index.js
Then restart your instance and your slideshow platform will be online.
Slideshow
Terminal output:
 ~ $ rm -rf www
~ $ git clone https://github.com/nafeu/realtime-slides-tut.git www
Cloning into 'www'...
remote: Enumerating objects: 91, done.
remote: Total 91 (delta 0), reused 0 (delta 0), pack-reused 91
Extracting objects: 100% (91/91), done.
~ $ cd www
~/www $ npm install --save
npm WARN realtime-slides-tut@1.0.0 No repository field.
added 297 packages from 253 contributors and audited 297 packages in 6.689s
found 18 vulnerabilities (9 low, 3 moderate, 5 high, 1 critical)
  run `npm audit fix` to fix them, or `npm audit` for details
~/www $ ln -fs server.js index.js
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Related articles
