Install Camaleon on your POWER web hosting plan
Knowledge Base
Icons/System/eye-open Created with Sketch. 245 Views 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Ruby applications, and you want to deploy Camaleon on it.
Find out how to install Camaleon on your POWER web hosting plan.
Let's suppose you have the default configuration for Ruby hosting:
  • Runtime: Ruby 2.6
  • Entrypoint: config.ru
  • DocumentRoot: www
  • Environment:development
Be careful, Rails depends on the environment (RAILS_ENV).
Connect via SSH to your POWER web hosting.
Delete your DocumentRoot to initiate it with Rails (don't forget to export your gempath or your bundle install will fail):
rm -rf www
gem env gempath
export GEM_HOME=$(gem env gempath | cut -d ':' -f1)
export RAILS_ENV=${OVH_ENVIRONMENT}
rails new www
cd www/
rails  webpacker:install
Prepare your Gemfile:
echo "gem 'camaleon_cms', '>= 2.4.5'" >> Gemfile
echo "gem 'draper', '~> 3'"  >> Gemfile
echo "gem 'execjs', '>= 2.7.0'"  >> Gemfile
Install your Gems:
bundle install
Force the right Node.js engine for Camaleon Javascript:
sed -i 's@\["nodejs", "node"\],@["/usr/local/nodejs14/bin/node"],@' ${GEM_HOME}/gems/execjs-2.7.0/lib/execjs/runtimes.rb
Run Camaleon with your sqlite database (beware, there are four different commands to run):
rails generate camaleon_cms:install
rake camaleon_cms:generate_migrations
rake db:migrate
rake assets:precompile
Now whitelist your domain name, in www/config/environments/development.rb:
Rails.application.configure do
  # Whitelist one hostname
  config.hosts << "your-domain.ovh"
Deactivate check_yarn_integrity check under section development in www/config/webpacker.yml:
development:
  <<: *default
  compile: true
  # Verifies that correct packages and versions are installed by inspecting package.json, yarn.lock, and node_modules
  check_yarn_integrity: false
Then restart your instance and your Camaleon will be online.
Camaleon
Terminal output:
~ $ rm -rf www
~ $ gem env gempath
/homez.41/powerlp/.gem/ruby/2.6.0:/usr/local/ruby2.6/lib/ruby/gems/2.6.0
~ $ export GEM_HOME=$(gem env gempath | cut -d ':' -f1)
~ $ export RAILS_ENV=${OVH_ENVIRONMENT}
~ $ rails new www
      create
      create  README.md
      create  Rakefile
      create  .ruby-version
Fetching webpacker 4.3.0
Installing webpacker 4.3.0
Bundle complete! 17 Gemfile dependencies, 75 gems now installed.
Use `bundle info [gemname]` to see where a bundled gem is installed.
         run  bundle binstubs bundler
Installing all JavaScript dependencies [4.3.0]
         run  yarn add @rails/webpacker@4.3.0 from "."
yarn add v1.22.10
├─ strip-eof@1.0.0
├─ thunky@1.1.0
├─ type-is@1.6.18
├─ unpipe@1.0.0
├─ url-parse@1.4.7
├─ utils-merge@1.0.1
├─ wbuf@1.7.3
├─ webpack-dev-middleware@3.7.3
├─ webpack-dev-server@3.11.2
├─ websocket-driver@0.7.4
├─ websocket-extensions@0.1.4
└─ ws@6.2.1
Done in 6.19s.
Webpacker successfully installed 🎉 🍰
~ $ cd www/
~/www $ rails  webpacker:install
   identical  config/webpacker.yml
Copying webpack core config
       exist  config/webpack
   identical  config/webpack/development.js
   identical  config/webpack/environment.js
   identical  config/webpack/production.js
   identical  config/webpack/test.js
info Direct dependencies
└─ webpack-dev-server@3.11.2
info All dependencies
Done in 3.81s.
~/www $ echo "gem 'camaleon_cms', '>= 2.4.5'" >> Gemfile
~/www $ echo "gem 'draper', '~> 3'"  >> Gemfile
~/www $ echo "gem 'execjs', '>= 2.7.0'"  >> Gemfile
~/www $ bundle install
Fetching gem metadata from https://rubygems.org/.........
Resolving dependencies.....
Using rake 12.3.2
Using concurrent-ruby 1.1.5
Using uglifier 4.1.20
Using web-console 3.7.0
Bundle complete! 20 Gemfile dependencies, 103 gems now installed.
Use bundle info [gemname] to see where a bundled gem is installed.
~/www $ sed -i 's@\["nodejs", "node"\],@["/usr/local/nodejs14/bin/node"],@' ${GEM_HOME}/gems/execjs-2.7.0/lib/execjs/runtimes.rb
 ~/www $ rails generate camaleon_cms:install
Running via Spring preloader in process 3807
WARNING: Spring is running in production. To fix this make sure the spring gem is only present in `development` and `test` groups in your Gemfile and make sure you always use `bundle install --without development test` in production
      create  config/system.json
      create  lib/plugin_routes.rb
       exist  app/apps
      create  app/apps/themes/readme.txt
       exist  app/apps/themes
      create  app/apps/themes/new/views/search.html.erb
      append  app/assets/config/manifest.js
      append  config/initializers/assets.rb
      append  Gemfile
 ~/www $ rake camaleon_cms:generate_migrations
Copied migration 20210203210456_create_active_storage_tables.active_storage.rb from active_storage
Copied migration 20210203210457_create_action_mailbox_tables.action_mailbox.rb from action_mailbox
Copied migration 20210203210458_create_action_text_tables.action_text.rb from action_text
Copied migration 20210203210459_create_db_structure.cama_contact_form_engine.rb from cama_contact_form_engine
Copied migration 20210203210469_create_media.camaleon_cms_engine.rb from camaleon_cms_engine
Copied migration 20210203210470_adjust_field_length.camaleon_cms_engine.rb from camaleon_cms_engine
 ~/www $ rake db:migrate
== 20210203210456 CreateActiveStorageTables: migrating ========================
-- create_table(:active_storage_blobs, {})
   -> 0.0020s
-- add_index("cama_posts", :slug, {:length=>255})
   -> 0.0011s
-- change_column("cama_term_taxonomy", :name, :text, {})
   -> 0.0141s
== 20210203210470 AdjustFieldLength: migrated (0.0479s) =======================
~/www $ rake assets:precompile
yarn install v1.22.10
[1/4] Resolving packages...
success Already up-to-date.
Done in 0.70s.
I, [2021-02-03T21:06:42.780527 #6031]  INFO -- : Creating symlink /home/powerlp/www/public/assets/tinymce/skins/lightgray/fonts/tinymce.eot
I, [2021-02-03T21:06:42.781108 #6031]  INFO -- : Creating symlink /home/powerlp/www/public/assets/tinymce/skins/lightgray/fonts/tinymce.eot.gz
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Related articles
