Install WikiJS on your POWER web hosting plan
Knowledge Base
Icons/System/eye-open Created with Sketch. 1701 Views 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Node.js applications, and you want to deploy a WikiJS wiki platform on it.
Find out how to install WikiJS on your POWER web hosting plan.
  • Runtime: nodejs 14
  • Entrypoint: index.js
  • DocumentRoot: www
Connect via SSH to your POWER web hosting.
Let's begin by going into the www folder and retrieving WikiJS source:
cd www
wget https://github.com/Requarks/wiki/releases/download/2.5.170/wiki-js.tar.gz
tar xzf wiki-js.tar.gz
rm -f wiki-js.tar.gz
Create a config.yml file:
port: 3000
db:
  type: sqlite
  storage: database.sqlite
logLevel: info
dataPath: ./data
and rebuild the sqlite3 module:
npm rebuild sqlite3
Make the symlink for the entry point:
ln -fs server/index.js index.js
Then restart your instance and your WikiJS will be online.
WikiJS
Terminal output:
 ~ $ cd  www
~/www $ wget https://github.com/Requarks/wiki/releases/download/2.5.170/wiki-js.tar.gz
--2021-02-03 14:50:23--  https://github.com/Requarks/wiki/releases/download/2.5.170/wiki-js.tar.gz
Resolving github.com (github.com)… 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443… connecté.
TTP request sent, awaiting response... 200 OK
Length: 65010291 (62M) [application/octet-stream]
Saving to: « wiki-js.tar.gz »
wiki-js.tar.gz                100%[===============================================>]  62,00M  19,9MB/s    ds 3,1s
2021-02-03 14:50:28 (19,9 MB/s) — « wiki-js.tar.gz » saved [65010291/65010291]
~/www $ tar xzf wiki-js.tar.gz
~/www $ rm -f wiki-js.tar.gz
~/www $ vi config.yml
port: 3000
db:
  type: sqlite
logLevel: info
dataPath: ./data
~/www $ npm rebuild sqlite3
> sqlite3@5.0.0 install /home/user/www/node_modules/sqlite3
> node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using request for node-pre-gyp https download
[sqlite3] Success: "/home/user/www/node_modules/sqlite3/lib/binding/napi-v3-linux-x64/node_sqlite3.node" already installed
Pass --update-binary to reinstall or --build-from-source to recompile
sqlite3@5.0.0 /home/user/www/node_modules/sqlite3
~/www $ ln -fs server/index.js index.js
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Related articles
