Install Ghost on your POWER web hosting plan
Knowledge Base
Icons/System/eye-open Created with Sketch. 411 Views 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Node.js applications, and you want to deploy a Ghost blogging platform on it.
Find out how to install Ghost on your POWER web hosting plan.
  • Runtime: nodejs 14
  • Entrypoint: index.js
  • DocumentRoot: www
To verify your configuration, you can use the Retrieve active configuration API endpoint
Connect via SSH to your POWER web hosting. Let's begin by configuring the domain name in a DOMAIN variable:
echo "Enter your domain (my-domain.ovh for example):"
read DOMAIN
Then install Ghost using npm at your home folder (not www):
cd $HOME
npm install ghost-cli@latest
export PATH=$HOME/node_modules/.bin:$PATH
rm -rf www
# Install Ghost
ghost install local --development --dir www --no-setup --no-start --no-enable
# Setup configuration
cd www
cat << EOF > config.${OVH_ENVIRONMENT}.json
  "url": "https://${DOMAIN}",
  "paths": {
    "contentPath": "content"
  "database": {
    "client": "sqlite3",
    "connection": {
      "filename": "content/data/ghost-development.db"
    "useNullAsDefault": true,
    "debug": false
EOF
# Symlink index.js entrypoint
VERSION=$(ghost --version | sed -n 's/Ghost version: \([0-9.]*\).*/\1/p')
ln -fs versions/${VERSION}/index.js index.js
Restart your instance and your Ghost will be online.
Ghost
Terminal output:
 $ echo "Enter your domain (my-domain.ovh for example):"
~/www $ read DOMAIN
power.mydomain.ovh
~/www $ cd $HOME
~ $ npm install ghost-cli@latest
> yarn@1.22.10 preinstall /home/powerlp/node_modules/yarn
> :; (node ./preinstall.js > /dev/null 2>&1 || true)
+ ghost-cli@1.15.3
added 420 packages from 208 contributors and audited 420 packages in 20.791s
`npm audit fix` to fix them, or `npm audit` for details
~ $ export PATH=$HOME/node_modules/.bin:$PATH
~ $ rm -rf www
~ $ ghost install local --development --dir www --no-setup --no-start --no-enable
✔ Checking system Node.js version
✔ Checking current folder permissions
✔ Checking memory availability
✔ Checking free space
✔ Checking for latest Ghost version
✔ Setting up install directory
✔ Downloading and installing Ghost v3.41.3
✔ Finishing install process
~ $ cd www
~/www $ cat << EOF > config.${OVH_ENVIRONMENT}.json
>   "paths": {
>   "database": {
>     "connection": {
>     "debug": false
> EOF
~/www $ VERSION=$(ghost --version | sed -n 's/Ghost version: \([0-9.]*\).*/\1/p')
~/www $ ln -fs versions/${VERSION}/index.js index.js
~/www $ mkdir -p tmp
~/www $ touch tmp/restart.txt
Related articles
