Technical capabilities
Knowledge Base
Icons/System/eye-open Created with Sketch. 3461 Views 20.05.2025 Managed Bare Metal
This page provides an overview of the technical capabilities and limitations of OVHcloud Managed Bare Metal services.
Capabilities and known limits
ItemDescriptionValue
Max. number of PCCs per customer IDNumber of vCenters or packs per organisationNo limit
Number of linked PCCsvCenters linked (Enhanced Linked Mode)0 (not allowed)
Minimum hosts per PCC (SLA)Number of hosts per vCenter to maintain SLA2
Minimum hosts per PCC (no SLA)Bare minimum hosts to work with vCenter without SLA0
Max. number of hosts per clusterHosts per cluster64
Max. number of clusters per vDCNumber of cluster within the same virtual data centreNo limit
Max. number of vDCs per PCCVirtual data centres customers can add per vCenter400
Max. number of hosts per PCCLimits of hosts per vCenterrange Hosts: 340 hosts, 70 zpools
range Hybrid: 241 hosts, 120 zpools
range BigDS: 76 hosts, 205 zpools
Max. number of VMs per SDDCVMs managed by the same vCenter25000
Max. number of VMs per hostVMs hosted on the same physical host1024
Max. number of IPs per PCCMax. number of Public IPs assignable and usable per vCenter1 x /23
vCPUs, RAM and disk consumed by regular vCenterResources assigned to vCenter (VCSA)4 vCPU, 16GB RAM, 290GB Disk
vCPUs, RAM and disk consumed by regular vROPSResources assigned to vROPS4 vCPU, 16GB RAM
Max. number of IPSec VPN TunnelsMax. number of VPN tunnels per edge512 compact edge
1600 large edge
4096 quad large edge
6000 extra large edge
Max. number of vRack per vDCMax. number of private networks per virtual data centre1
Max. number of L2 VPN ClientsNumber of VPN clients to connect5
TPM (Trusted Platform Module)Possibility to secure VMs using TPM by protecting encryption keysNot supported
Related articles
