KB0045681
Technical capabilities
This page provides an overview of the technical capabilities and limitations of OVHcloud Hosted Private Cloud services.
Capabilities and known limits
| Item | Description | Value |
| Max. number of PCCs per customer ID | Number of vCenters or packs per organisation | No limit |
| Number of linked PCCs | vCenters linked (Enhanced Linked Mode) | 0 (not allowed) |
| Minimum datastores per PCC (SLA) | Number of datastores per vCenter to maintain SLA | 2 |
| Minimum hosts per PCC (SLA) | Number of hosts per vCenter to maintain SLA | 2 |
| Minimum hosts per PCC (no SLA) | Bare minimum hosts to work with vCenter without SLA | 0 |
| Max. number of hosts per cluster | Hosts per cluster | 64 |
| Max. number of clusters per vDC | Number of cluster within the same virtual data centre | No limit |
| Max. number of vDCs per PCC | Virtual data centres customers can add per vCenter | 400 |
| Max. number of hosts per PCC | Limits of hosts per vCenter | 231 |
| Max. number of datastores per PCC | Limits of datastores per vCenter | 110 |
| Max. number of VMs per SDDC | VMs managed by the same vCenter | 25000 |
| Max. number of VMs per host | VMs hosted on the same physical host | 1024 |
| Max. number of IPs per PCC | Max. number of Public IPs assignable and usable per vCenter | 1 x /23 |
| vCPUs, RAM and disk consumed by regular vCenter | Resources assigned to vCenter (VCSA) | 4 vCPU, 16GB RAM, 290GB Disk |
| vCPUs, RAM and disk consumed by regular NSX | Resources assigned to NSX Manager and Controller | 4 vCPU, 4GB RAM, 60GB Disk 4 vCPU, 2GB RAM, 28GB Disk |
| vCPUs, RAM and disk consumed by regular vROPS | Resources assigned to vROPS | 4 vCPU, 16GB RAM |
| Max. number of edge nodes | Max. number of edge devices to be deployed per NSX | 2000 |
| Max. number of IPSec VPN Tunnels | Max. number of VPN tunnels per edge | 512 compact edge 1600 large edge 4096 quad large edge 6000 extra large edge |
| Max. number of vRack per vDC | Max. number of private networks per virtual data centre | 1 |
| Max. number of L2 VPN Clients | Number of VPN clients to connect | 5 |
| Max. number of whitelisted IPs | Number of IPs allowed to connect to your VMware infrastructure | 2048 |
Secure Shell (SSH) : un protocole de réseau sécurisé utilisé pour établir des connexions entre un client et un serveur. Il permet d'exécuter des commandes à distance de manière sécurisée. ↩
