Using TypeScript on your POWER web hosting plan
Wissensdatenbanken
Icons/System/eye-open Created with Sketch. 64 Ansichten 04.02.2021 POWER Web Hosting
You've subscribed to a Web POWER web hosting plan to deploy Node.js applications, and you want to deploy TypeScript code.
Find out how to install Strapi on your POWER web hosting plan.
TypeScript projects can't run directly by our stack, they should be compiled to JS first.
You should include typescript as dev dependency module for your project:
npm add --save-dev typescript
Create a tsconfig.json (if you don't have one already) with the following content for example (see the TypeScript doc for more information):
  "compilerOptions": {
    "target": "es6",
    "module": "commonjs",
    "rootDir": "./",
    "outDir": "./build",
    "esModuleInterop": true,
    "strict": true
Build the project, either directly with tsc command:
npx tsc  --project ./
or by adding the build script to the package.json:
"scripts": {
  "build": "tsc --project ./"
and executing it with npm run build.
Your entrypoint should point to the one in your output dir, for example :
ln -s build/server.js server.js
Zugehörige Artikel
