Using Codefresh with OVHcloud Managed Kubernetes cluster
Wissensdatenbanken
Icons/System/eye-open Created with Sketch. 299 Ansichten 01.07.2019 Cloud / Managed Kubernetes Service
In this tutorial we will see how you can connect Codefresh, a CI/CD platform for Kubernetes, to an OVHcloud Managed Kubernetes cluster.
Before you begin
The first thing you need to follow this tutorial is a Codefresh account, you can get it directly at Codefresh site.
Codefresh
This tutorial also presupposes that you already have a working OVHcloud Managed Kubernetes cluster, and some basic knowledge of how to operate it. If you want to know more on those topics, please look at the OVHcloud Managed Kubernetes Service Quickstart.
Connect an OVH Kubernetes cluster to Codefresh dashboard
You can use the Codefresh GUI to connect your OVHcloud Managed Kubernetes cluster to Codefresh. In Codefresh GUI, start by going into your Account Configuration, by clicking on Account Settings on the left sidebar. On the first section called Integrations click the Configure button next to Kubernetes.
As the current time, Codefresh doesn't propose a direct integration with OVHcloud Managed Kubernetes Service, so you will have to add your cluster manually. To do it, click on the Add provider button and select Custom providers.
The integration between Codefresh and your Kubernetes cluster is API based and relies on a Kubernetes service account of your choosing that will be used to manage the integration.
The configurations you’ll be required to add are:
  1. Name - Any name of your choosing, that will represent your cluster context in Codefresh.
  2. Host - The full URL of the Kubernetes API endpoints including protocol and port
  3. Certificate - The Kubernetes service account certificate used for the integration with Codefresh (base64 encoded)
  4. Token - The Kubernetes service account token used for the integration with Codefresh (base64 encoded)
Let's see how you can obtain these parameters, using kubectl.
Set the permissions
In order to allow Codefresh to connect to your cluster, you need to set up a Role, a ServiceAccount and a RoleBinding. Create a codefresh-role-sa-bind.yml YAML file:
kind: ClusterRole
apiVersion: rbac.authorization.k8s.io/v1
metadata:
rules:
  - apiGroups: [""]
    resources: ["*"]
    verbs: ["list", "watch", "get"]
apiVersion: v1
kind: ServiceAccount
metadata:
  namespace: kube-system
apiVersion: rbac.authorization.k8s.io/v1beta1
kind: ClusterRoleBinding
metadata:
roleRef:
  apiGroup: rbac.authorization.k8s.io
  kind: ClusterRole
subjects:
- kind: ServiceAccount
And apply it using kubectl:
kubectl apply -f codefresh-role-sa-bind.yml
The Role, the ServiceAccount and the RoleBinding are created:
$ kubectl apply -f codefresh-role-sa-bind.yml
clusterrole.rbac.authorization.k8s.io/codefresh-role created
serviceaccount/codefresh-user created
clusterrolebinding.rbac.authorization.k8s.io/codefresh-user created
Getting the Host
Use kubectl to get the full URL of the OVHcloud Managed Kubernetes API endpoints:
kubectl cluster-info
The Host parameter is the URL of the Kubernetes master.
$ kubectl cluster-info
Kubernetes master is running at https://xxxxxxxx.c1.gra.k8s.ovh.net
KubeDNS is running at https://xxxxxxxx.c1.gra.k8s.ovh.net/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
To further debug and diagnose cluster problems, use 'kubectl cluster-info dump'.
In my example cluster, the Host is https://xxxxxxxx.c1.gra.k8s.ovh.net.
Getting the Certificate
Use kubectl to generate a certificate:
echo $(kubectl get secret --namespace kube-system  -o go-template='{{index .data "ca.crt" }}' $(kubectl get sa codefresh-user --namespace kube-system -o go-template="{{range .secrets}}{{.name}}{{end}}"))
Copy the generated certificate into the Certificate field on Codefresh.
$ echo $(kubectl get secret --namespace kube-system -o go-template='{{index .data "ca.crt" }}' $(kubectl get sa codefresh-user --namespace kube-system -o go-template="{{range .secrets}}{{.name}}{{end}}"))
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
Getting the Token
Use kubectl to generate a token:
echo $(kubectl get secret --namespace kube-system -o go-template='{{index .data "token" }}' $(kubectl get sa codefresh-user --namespace kube-system -o go-template="{{range .secrets}}{{.name}}{{end}}"))
Copy the generated token into the Token field on Codefresh.
$ echo $(kubectl get secret -o go-template='{{index .data "token" }}' $(kubectl get sa default -o go-template="{{range .secrets}}{{.name}}{{end}}"))
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
Test and save the connection
Click on the Test connection button to test the configuration. You should get a message telling you that your OVHcloud Managed Kubernetes cluster connects successfully with Codefresh:
Then click on Save to save your cluster on your Codefresh Dashboard.
And now?
Now you can follow Codefresh official tutorial to deploy a Docker image to a Kubernetes cluster and also how to setup an automated pipeline to automatically redeploy it when the source code changes.
Zugehörige Artikel
