Hot-Swapping a Disk on Hardware RAID Dedicated Servers
Wissensdatenbanken
Icons/System/eye-open Created with Sketch. 687 Ansichten 21.08.2023 Cloud / Dedicated Server (Bare Metal)
Hot swapping is only possible on the server ranges mHG, HG, and bHG.
To carry out the various steps of this guide, you must:
  • Have a server mHG, HG, or bHG.
  • Have a hardware RAID server (with a MegaRAID card).
  • Have access to SSH (Linux and VmWare ESXi).
  • Have access to RDP (Windows).
  • The MegaCLI and / or StorCLI utilities must be installed (normally by default).
In Linux
Step 1: Identify the disk to be replaced
In order to replace a disk, you will have to provide the technician with the Enclosure ID, the slot ID, and the Serial Number of the disk to be replaced.
Or otherwise (disk not detected for ex), the same information but for disks that are NOT to replace and specify it to the technician.
We will start by listing the disks on the server. While being able to retrieve the information cited above.
List of disks
To list the disks, you can use the following command: MegaCli -PdList -aALL | Egrep "Slot | Device ID | Device Id"
For example :
 MegaCli -PdList -aALL | egrep "Slot|Device ID|Device Id"
Enclosure Device ID: 252
Slot Number: 0
Device Id: 6
Slot Number: 1
Device Id: 5
Slot Number: 2
Device Id: 4
Slot Number: 3
Device Id: 7
The MegaCli -PdList -aALL command, without GREP, can display all information on a disk.
Equivalent via the storcli command :
 storcli /call show all
PD LIST :
EID:Slt DID State DG       Size Intf Med SED PI SeSz Model               Sp
252:0     6 Onln   0 744.687 GB SATA SSD N   N  512B INTEL SSDSC2BB800H4 U
252:1     5 Onln   0 744.687 GB SATA SSD N   N  512B INTEL SSDSC2BB800H4 U
252:2     4 Onln   0 744.687 GB SATA SSD N   N  512B INTEL SSDSC2BB800H4 U
252:3     7 Onln   0 744.687 GB SATA SSD N   N  512B INTEL SSDSC2BB800H4 U
This is an excerpt from the return of the storcli command. Other information is visible, like the listing of the disks according to the raids etc ...
With MegaCLI, you can also list disks according to the raids with this command: MegaCli -CfgDsply -a0.
Test and identify a disk :
To test a disk / identify its serial number, you must perform the smartctl command as follows :
 smartctl -a -d megaraid,6 /dev/sda | grep Serial
Serial Number:    BTWH509602CV800CGN
The number 6 in this command corresponds to the Device ID of the disk (Device ID under MegaCLI, and DID under storCLI).
This information is found in the disk listing, performed in the previous step.
We now know the Enclosure ID, the Slot ID, and the Serial Number of the drive to be replaced.
Step 2: Turn on a disk
To allow the technician to replace your drive with heater, the HS drive must be switched on (flashing).
In our example, we have Enclosure ID 252, Slot ID 0, and Serial Number BTWH509602CV800CGN to be replaced.
The command to flash the disk is as follows: MegaCli -PdLocate -start -physdrv [EncID: SlotID] -a0.
 MegaCli -PdLocate -start -physdrv[252:0] -a0
Adapter: 0: Device at EnclId-252 SlotId-0  -- PD Locate Start Command was successfully sent to Firmware
Exit Code: 0x00
 rescue:~# storcli /call /e252 /s0 start locate
Controller = 0
Status = Success
Description = Start Drive Locate Succeeded.
To turn the disk off after the operation, simply replace the "start" with "stop" in the above commands.
At this point, the procedure is ready to be performed. You can then provide the previously collected information to the support team and indicate that the disk is turned on.
Step 3: Check the rebuilding
Once the intervention scheduled in the Datacenter is completed, you can re-test the RAID and disks, and see that the replaced disk is in Rebuild.
 MegaCli -PdList -aALL | egrep "Slot|Device ID|state"
Slot Number: 0
Firmware state: Rebuild
Slot Number: 1
Firmware state: Online, Spun Up
PD LIST :
252:0     6 Rbld   0 744.687 GB SATA SSD N   N  512B INTEL SSDSC2BB800H4 U
The RAID is in state Degraded the time of reconstruction, this is normal.
 MegaCli -LDInfo -Lall -aALL
Adapter 0 -- Virtual Drive Information:
 Drive: 0 (Target Id: 0)
Name                :
RAID Level          : Primary-1, Secondary-0, RAID Level Qualifier-0
Sector Size         : 512
Is VD emulated      : Yes
Mirror Data         : 1.454 TB
State               : Degraded
Strip Size          : 256 KB
Number Of Drives per span:2
Span Depth          : 2
Default Cache Policy: WriteThrough, ReadAhead, Direct, No Write Cache if Bad BBU
Current Cache Policy: WriteThrough, ReadAhead, Direct, No Write Cache if Bad BBU
Default Access Policy: Read/Write
Current Access Policy: Read/Write
Disk Cache Policy   : Enabled
Encryption Type     : None
Bad Blocks Exist: No
PI type: No PI
Is VD Cached: No
Exit Code: 0x00
Finally, you can also check the progress of the rebuild with the following command MegaCli -PDRbld -ShowProg -PhysDrv [EncID: SlotID] -a0
 MegaCli -PDRbld -ShowProg -PhysDrv [252:0] -a0
Rebuild Progress on Device at Enclosure 252, Slot 0 Completed 93% in 0 Minutes.
Exit Code: 0x00
 storcli /call /e252 /s0 show rebuild
In Windows
This guide is based on a Windows Server 2012 R2 Standard system. The MegaRaid Storage Manager tool is installed by default.
Step 1 : Verify that the server has a MegaRaid card
So we go to the menu Device management, and we see the presence of the MegaRaid card (9271-4i)
device
Step 2 : Identify the disk to be replaced
At first, we will open MegaRAID Storage Manager.
login
Then click Login, and fill in your login/password. (The manipulations in our case are carried out by being Administrator).
Then we arrive on the Management screen of the MegaRaid card.
dashboard
We will now check the Serial Number of our HS drive and its position in the server (Enclosure ID and Slot ID).
We go to the Logical tab, and we get to this.
logical-view-2
On this screen, a lot of information is present.
We see, on the left, the logical view of our RAID. Here we have a RAID 10 (id0) in optimal state. It consists of two clusters of 2 disks.
We can see that our Slot Number 1 drive is in the 1st cluster. On the right side of the screen, we retrieve the information we need (Enclosure / Slot / Serial).
So our disk has for Enclosure ID 252, Slot Number 1, and Serial Number BTWH509504BN800CGN.
From now on, we will be able to light (physically flash) the disk to be replaced for replacement by a Datacenter technician.
Step 3 : Turn on a disk
With the MegaRAID Storage Manager it will be very easy to turn on the LED of the disk to be replaced.
First of all, it is better to stop the Locator on each disk in order to avoid any error in Datacentre. Indeed, if during a previous intervention the LED has not been turned off, there will be two disks of lights on the server.
To do this, right click on each disk, and click on stop locating drive.
stop-locate
Now we can turn on the disk we are interested in.
Right click on our disk, Slot ID 1, and Serial Number BTWH509504BN800CGN.
clic-locate
Then click on start locating drive
At this point, the procedure is ready to be performed. You can then provide the information previously gathered (Enclosure ID, Slot ID, and Serial Number), and indicate that the drive is turned on.
Step 4 : Check the rebuilding
Once you have completed the Datacenter, you can go back to the MegaRAID Storage Manager in the Background operations and check that the disk is Rebuild.
MegaRAID background operations showing disk rebuild
The detail will return you this type of result :
Rebuild progress detail for replaced disk
Also, on the Logical tab, we always have the details of RAID and disks.
Logical tab showing RAID status and disk rebuild
The Slot ID 1 is in doing of Rebuild.
The RAID is in degraded state during Rebuild, which is normal.
Finally, it is preferable to repeat the operation of the stop locate seen previously for the disk that has just been replaced.
In VmWare ESXi
In this guide, we assume you have received an alert for the failed Slot Number 1, Serial Number BTWA547608CE800HGN and you want to replace it hot.
For this we will need the Enclosure ID, the Slot Number, and Serial Number of the disk to be replaced to communicate them to the Datacentre.
The MegaCLI tool must be installed on the server.
Before continuing, we will verify that the server has a MegaRAID card.
 lspci | grep -i mega
0000:81:00.0 Mass storage controller: Avago (LSI / Symbios Logic) MegaRAID SAS Fusion Controller [vmhba2]
Via the Vsphere client, you can also find this information in Manage, then Hardware Tab.
gerer-host
We have an LSI MegaRAID card.
For a disk replacement, the Enclosure ID, Slot Number, and Serial Number must be supplied to the Data Center of the drive to be replaced.
If the disk is no longer detected, for example, it will be necessary to provide the same information from all other disks to DO NOT replace.
At first, we will list the disks present on the server while being able to recover the information listed above.
List of disks
 [root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PdList -aALL | egrep "Slot|Device ID|Device Id"
Slot Number: 0
Device Id: 4
Slot Number: 1
Device Id: 7
Slot Number: 2
Device Id: 5
Slot Number: 3
Device Id: 6
We have therefore recovered the ID of our HS Slot Number 1 which is Device ID 7, and its Enclosure ID 252.
To perform the replacement operation, the HS drive must be switched on (flashing).
Before turning on the LED of the disk that interests us here, we will first go through each disk to turn off the LEDs (in case a LED is always on after a previous intervention).
In this case, we have 4 disks that have as Enclosure ID 252, and as Slot Number 1, 2, 3, and 4.
We will use the following command: ./MegaCli -PdLocate -stop -physdrv [EncID: SlotID] -a0
 [root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PdLocate -stop -physdrv[252:0] -a0
Adapter: 0: Device at EnclId-252 SlotId-0  -- PD Locate Stop Command was successfully sent to Firmware
Exit Code: 0x00
[root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PdLocate -stop -physdrv[252:1] -a0
Adapter: 0: Device at EnclId-252 SlotId-1  -- PD Locate Stop Command was successfully sent to Firmware
Exit Code: 0x00
[root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PdLocate -stop -physdrv[252:2] -a0
Adapter: 0: Device at EnclId-252 SlotId-2  -- PD Locate Stop Command was successfully sent to Firmware
Exit Code: 0x00
[root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PdLocate -stop -physdrv[252:3] -a0
Adapter: 0: Device at EnclId-252 SlotId-3  -- PD Locate Stop Command was successfully sent to Firmware
Exit Code: 0x00
We now switch to the disk we want to replace to turn on the LED.
To do this, we use the following command: ./MegaCli -PdLocate -start -physdrv[EncID:SlotID] -a0
 [root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PdLocate -start -physdrv[252:1] -a0
Adapter: 0: Device at EnclId-252 SlotId-1  -- PD Locate Start Command was successfully sent to Firmware
Exit Code: 0x00
At this point, the procedure is ready to be performed. You can then provide the information previously gathered (Enclosure ID, Slot Number or Slot ID, Serial Number), and indicate that the disk is turned on.
Once you have completed the Datacenter, you can re-test RAID and disks to verify that the replaced disk is in Rebuild.
 [root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PdList -aALL | egrep "Slot|Device ID|state"
Slot Number: 0
Slot Number: 1
Slot Number: 2
Slot Number: 3
The RAID is in degraded state during rebuild, which is normal.
You can also check the progress of the rebuild with the following command :
 [root@ns3043198:/opt/lsi/MegaCLI] ./MegaCli -PDRbld -ShowProg -PhysDrv [252:1] -a0
Rebuild Progress on Device at Enclosure 252, Slot 1 Completed 93% in 0 Minutes.
Exit Code: 0x00
Managing hardware RAID
Configuring MegaRAID for RAID Level 0
OVHcloud API and Storage
Managing software RAID
Hot Swap - Software RAID
Zugehörige Artikel
